Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 18th March 2003, 06:31 PM   #1
Lucas_G is offline Lucas_G
Default Aleph 5 playing...
I have finally got some pictures of my two new Aleph 5 monoblocks.
They were taken some 10 days ago when I had just started to listen to them.
You will see them in their naked version.
Meanwhile I have added the wooden sides and the aluminium tops and bottoms. The frontplate will be professionally made in a later stage.
Lucas.
In this picture you see the side of it:
The Condis were still not fixed, but hey cvould not fall out...
Old 18th March 2003, 06:33 PM   #2
View on the top:
Old 18th March 2003, 06:35 PM   #3
Other side:
Old 18th March 2003, 06:40 PM   #4
View from underneath:
Old 18th March 2003, 06:42 PM   #5
Also upsidedown:
Old 18th March 2003, 06:46 PM   #6
Again from underneath you see the 30 VAC transformator (330 VA) with next to it a small heatsink on to which two rectifierbridges are attached.
Old 18th March 2003, 06:52 PM   #7
These PCBs are Kristijan's...
I attached folded brass dog-pennings for cooling the 9610s.
Under the PCBs you first get a nylon ring, then an alunminium stripe, then the IRFP 240, then Kapton (non-grease) isolation, then a 3 mm thick redcopperbar, then grease, and finally the Seifert Heatsink, measuring 216 x 150 x 84 mm.
Old 18th March 2003, 06:55 PM   #8
Here you can again see how the Mosfets were attached:
(Sorry for the badly focused photo...)
You also see the AC filter inlet, and the thermal 80 degrees Celsius clickson.
Old 18th March 2003, 07:00 PM   #9
Here is a final (rather dark) picture where you can see the wooden sidepanels in a still rough state and one of the aluminium grids for the tops and bottoms.
(They have been installed now but I don't have a digital camera. I will post them later...)
Old 18th March 2003, 07:32 PM   #10
Some remarks on the components used:
The toroids are 30 VAC 330 VA from Reichelt, Germany. Very cheap (33 Euro) and very silent.
The Condensators are 45 Volt (56 Volt surge) Marcon 16.000 uF. I used 2 sets of 4 pieces in each monoblock, divided by Intertechnik 3,9 mH 0,24 Ohm I-Point chokes.
I use two rectifierbridges for each channel.
The 30 VAC result in a 39 VDC under load.
One channel delivers appr. 30 mV DC offset, the other one is around zero!
I matched all mosfets, and I also matched the 550BC on HFE.
I used 0.25 Watt 0,1% precision resistors made by Welwyn, and 5 Watt MOX resisters made by Intertechnik.
Since I too have 4 Ohm speakers I decided to use the resistorvalues of WuffWaff that he has posted in another thread. This leads to a higher bias.
The Seifert heatsinks reach a temperature of about 47 degrees Celsius at a roomtemperature of 20 degrees. The redcopperbar on which the mosfets are attached reaches 53 degrees.
We can therefor conclude that the redcopperbar is a good solution.
Now on to the sound:
I have borrowed a lot of commercial products in the 1000 up to 4000 Euro segment from a befriended Hifi-shop.
Most sounded horribly clean and sterile with a narrow spacing.
Only a Classé Audio amp was a bit more natural but its bass was weak.
The Aleph 5 is in another class: it lets you hear detail and space in recordings without ever getting harsh.
It is the most natural sound that I have heard.
Thank you Nelson Pass!
Regards to all,
Lucas.
Thread Tools
Just playing with my Charlize andy2667 Class D 87 14th August 2008 08:14 PM
Now playing… martyh Analogue Source 2 27th June 2008 02:46 PM
Playing with ROMs Zero One Digital Source 0 13th May 2007 12:18 PM
what's better, a mid playing high, or a tweet playing low??? cody6766 Multi-Way 10 20th February 2005 09:40 PM
Playing with a Magic Eye. Shoog Tubes / Valves 7 13th January 2005 09:33 PM
Page generated in 0.11394000 seconds (81.30% PHP - 18.70% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
