Old 19th March 2003, 04:24 PM   #21
Lucas_G is offline Lucas_G  Netherlands
Try again:
Old 19th March 2003, 04:28 PM   #22
A few questions;
How long was your amp running when you measured the your 47 degrees?
More than a hour?
What was the ambient temperature in your room?
What did you pay in euro's for the heatsink?
Thanks,
Edwin
Old 19th March 2003, 04:45 PM   #23
Originally posted by Edwin Dorre
A few questions;
More than a hour?
Thanks,
Edwin
Hi Edwin,
The amp was already running for a couple of hours.
The ambient temp in the room was 20 degrees Celsius.
I paid appr. 60 Euro per heatsink.
They also sell a 300 mm long model, called KL 271. It is not much more expensive, and it has a C/W of 0.11
Lucas.
Old 19th March 2003, 04:47 PM   #24
wuffwaff's Avatar
Lucas,
nice amp you´ve build there! I like the way it is build using all three dimensions. Most amps are more 2 dimensional in there layout (not meaning that they sound flat or so......).
Do you think the plant will survice for a long time?
William
P.S. how much ripple do you have and how much voltage do you loose over the chokes?
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 20th March 2003, 01:09 AM   #25
" Since I too have 4 Ohm speakers I decided to use the resistorvalues of WuffWaff that he has posted in another thread. This leads to a higher bias. "
__________________________________________________ __
Can some one lead me to this thread? Thanks..... Did a quick search but can't find it...
Mark
Old 20th March 2003, 09:26 AM   #26
Mark
Hi Mark,
Wuffwaff made there the following comment:
"Since the last reports I changed the trimmers for R19 and R21 with resistors (49k and 390R) so now it runs at 2.4A bias and about 63% ac current gain (about 6.7A peak)."
These are values that I used too.
Lucas.
Old 20th March 2003, 09:32 AM   #27
Originally posted by wuffwaff
Lucas,
William
Hi William,
Thanks for your praise! This 3 dimensional way of building was neccesary to get all things into such a compact space.
Apparently it makes it difficult for some to understand how it is set up...
The plant would not survive, I guess, and nor would I when my wife would found out...
I don't know how to measure ripple. I don't have a scope.
I tried Duncan's PSU design tool and it showed a very low ripple.
The voltage drop over the chokes is less than 1 Volt.
I am also amazed to see a ratio between 30 VAC / 39 VDC of 1.3
Much higher than I had expected.
Kindest regards and good luck with you Aleph-X project!
Lucas.
Old 20th March 2003, 09:20 PM   #28
Glad that the Seiferts are truthfull about their Cw value, because I have a pair the 300*200*83 mm KL271 for my Alpeh5s. Notice you also have some "spots" (beschadegingen) on them.
My youre amp is ugly btw Maybe I can make an even uglier one
PS The Seifert KL271 200 mm high costs 65 euro excl. taxes
Is that all there is?
Old 21st March 2003, 12:11 PM   #29
Hi Duck,
Yes, there were already some spots on them when I received them.
I guess you can can fix these with the help of a permanent marker lik an Edding...
I will do that only after finishing the outside of the amp (concealing what you seem to be finding utterly ugly ).
Lucas
Old 21st March 2003, 02:13 PM   #30
Here is a pic of my wannabe Aleph5 (still have to start building the mechanical part). It will be a dual mono case btw. Size will be 480 * 310 * 310 mm (on the outside ofcourse). It will have 2 layers. Below the elcos and conductors. Above it the trafo's (in the middle). PCBs at the sides against the Seiferts of course.
I will not be using a extra face plate or something, only L an T alu profiles.
Damn stains (fingerprints) on the aluminium.
Just playing with my Charlize andy2667 Class D 87 14th August 2008 09:14 PM
Now playing… martyh Analogue Source 2 27th June 2008 03:46 PM
Playing with ROMs Zero One Digital Source 0 13th May 2007 01:18 PM
what's better, a mid playing high, or a tweet playing low??? cody6766 Multi-Way 10 20th February 2005 10:40 PM
Playing with a Magic Eye. Shoog Tubes / Valves 7 13th January 2005 10:33 PM
Page generated in 0.11564 seconds (79.46% PHP - 20.54% MySQL) with 11 queries
