What's the Idle Current of the F5 Power Amp
Old 7th July 2008, 11:37 PM   #1
NV&H is offline NV&H  United States
Default What's the Idle Current of the F5 Power Amp
In his AudioXpress article, Nelson wrote that a power supply with a 6 amp continuous rating is needed. Does that mean that when the thing is powered up with no input signal, it's drawing that much?
Perhaps it draws less than that at idle with the 6 amp specified to ensure reliability?
NV&H
Old 8th July 2008, 12:55 AM   #2
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
1.3A, with +/-24Vdc rails makes ~62.5W dissipation per channel.
It's a Class A power amp, so you want the PS to have a nominal power rating a couple of times as much.
The F5 is also a Push-Pull design with an output stage that is strong enough to deliver a lot of peak current, another reason for desiring a bulky powersupply.
Read the first 15 to 20 pages of the F5 thread for continuous and peak current rating of the PS.
Old 8th July 2008, 12:56 AM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The rating refers to the capacity of the secondary windings.
The draw of the amplifier is about 80 watts per channel at idle,
which results in an (rms) draw of about 1.5A from the wall
at 120V for 2 channels. In Paris, that would be more like 0.75A.
Old 8th July 2008, 07:20 AM   #4
180W as in 2 x 62.5W x sqrt2.
Old 8th July 2008, 10:52 AM   #5
MEH is offline MEH  United States
Where'd the sqrt2 come from?
Old 8th July 2008, 12:18 PM   #6
Smoking Californian oak ?
The F5 manual reads 1.3A per leg, 25Vdc rails max, 62W dissipation per channel, makes 124W for stereo.
But also : power consumption = 180W and slow fused for 300W Max.
The amp is supposed to do 10A peak, 10A times 18V rms= 180W.
(if you add the bridge rectifier dissipation it becomes 133W/stereo)
Old 8th July 2008, 02:06 PM   #7
The one and only
You're right, 60 watts. I had 1.6A stuck in my head.
Old 8th July 2008, 02:54 PM   #8
If only,
none of the F5 scavengers noticed that the mains fuse is rated at 2.5A.
The production F5 has 1 transformer and 1 fuse, means the power supply is sized at 180VA to 225VA Max for both channels.
Basically means the F5 is dimensioned for 4 Ohm use : 20V rails /(4+0.47)~ 4.5A peak aka ~3.15A continuous.
3.15A times 25Vdc per channel times 2 comes to ~160VA, with a little cherry on top makes 180VA.
For 2 Ohm use the peak output current would be around 8A, makes ~5 3/4A continuous, results in a single 300VA transformer for both channels.
Some already indicated to use a 800VA biggy for the F5 they're assembling, they'll probably laugh at a 50W Accuphase P102 Class A amp that runs on a chicken-leg 160VA transformer per channel.
Old 9th July 2008, 01:26 AM   #9
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Thanks, Jacco.
Helpful info!
Old 9th July 2008, 01:30 AM   #10
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Yeah.... I hate it when the dang Grado short circuits.
Crazy Yankee.
What's the Idle Current of the F5 Power AmpHide this!Advertise here!
Idle current adjustment for NAD gvelim Solid State 0 5th August 2008 03:56 AM
nad 3020b idle current reddish75 Solid State 4 4th July 2008 02:46 PM
idle current for bryston 4B Danielll Solid State 2 3rd October 2005 05:25 PM
chip amp idle current maylar Chip Amps 2 29th December 2004 03:25 PM
XM-1502SX Idle Current sdoom Solid State 1 9th July 2004 07:35 AM
