diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Preamp ideas for F5 (http://www.diyaudio.com/forums/pass-labs/125893-preamp-ideas-f5.html)
ejfud 5th July 2008 03:43 PM
Preamp ideas for F5
What's everybody using with their F series amps?
Any good DIY options out there that are on the easy side to build?
juma 6th July 2008 11:16 AM
2 Attachment(s)
The one I attached will do nicely - it sounds very good and it's easy to build. F5 is very light load (100k).
R6/R1 ratio sets the gain (make them both 1k for the gain of 2V/V or 6 dB) and P1 sets the DC offset on output.
You can use F5's PS to make a regulated PS for this preamp.
Input pair of K170/J74 can be GR or BL ; output ones are BL or V.
juma 6th July 2008 11:25 AM
2 Attachment(s)
I tried it p2p and it's going to be part of my F5 that I'm making as integrated amp. This is a PCB for this preamp:
Holger Barske 6th July 2008 01:05 PM
Anything wrong with B1?
EUVL 6th July 2008 03:01 PM
F5 has a gain of 6, B1 has less than 1, and the one published above 2, making a total gain of 6 & 12 respectively.
Assuming you have no low level source like tape or phono, and only single ended CD at about +/-2V output max. That means a maximum output of +/-12V and +/-24V respectively. Not much left for volume control ??
Of course it would be just perfect if you have a digital attenuator in your source. Then maybe you don't even have to bother with the B1 and just connect the source straight to the F5.
Patrick
woody 6th July 2008 06:29 PM
If you refer to post # 47 by Pass in the f5 thread the amp
has 15.2 DB gain when run into a 8ohm load.
stefanobilliani 6th July 2008 08:53 PM
Not at all
Originally posted by EUVL
Assuming you have only single ended CD at about +/-2V output max. That means a maximum output of +/-12V and +/-24V respectively. Not much left for volume control ??
Patrick
Enjoying CD-B1-F5 and Jordan JX92S which are 88db SPL 1m 1w , very ok with volume control .
Ahhhh the B1 is very very good
Babowana 6th July 2008 09:20 PM
Very good.. but why good? Thanks..
juma 6th July 2008 09:27 PM
Nothing at all... Except that it's not a preamp - it's a unity gain buffer stage - the thread is about preamp. ;)
My source can't drive F5 to full power without additional gain (6 dB at least). :cannotbe:
stefanobilliani 6th July 2008 09:36 PM
Becouse of its sound and its volume control tracking . There is no changing in sound caracter turning the pot , the buffer is no feedback ... . IMHO much better than just a pot also when you are ok with impedance matching .
And of course it is a preamp . since it amplyfies the current of the signal .
Resources saved on this page: MySQL 18.75%
