Preamp ideas for F5
Preamp ideas for F5
Old 21st July 2012, 10:12 AM   #251
Antoinel is offline Antoinel  United States
Preamp ideas for F5
Originally Posted by massimo View Post
With a 3.300uF o/p cap?
Great catch. I see your point. Charging and discharging this cap by the input resistance of F5 willl be long. Load the [Amp Camp Amp] with a 33-100 Ohm resistor. I read it somewhere that Mr. Pass prefers any amp to do some work. Or resize the ouput cap!
Old 21st July 2012, 10:24 AM   #252
flg is offline flg  United States
flg's Avatar
R14?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 21st July 2012, 11:50 AM   #253
Preamp ideas for F5
Originally Posted by flg View Post
R14?
Thanks flg. The existing R14 = 1K Ohm [in amp] is to discharge the output capacitor. I see this Amp Camp Amp [ACA for short] doing double duty. A switch at its output to select either 'power amp' or 'pre-amp'. Either way, a volume control at its input is needed. Music Source to ACA to loudspeaker or music source to ACA to F5 or other to loudspeaker.
Old 21st July 2012, 12:20 PM   #254
Jay is offline Jay  Indonesia
Banned
I thought the Amp#1 was for beginners. Couldn't possibly compete with the other preamps already discussed in this thread, or I've missed something.
Old 21st July 2012, 12:45 PM   #255
Preamp ideas for F5
Your analysis may well be correct in the end. Still, your [bolded] statement is nonetheless a hypothesis. Prove it either way by doing the experiment. Maybe you [or others] have already built other low power Pass amplifiers of topology [opposed drains of output stage] like ACA [Zen, Aleph etc.]. Your hypothesis can then be easily/readily tested, and/or this experiment was already done.
Old 21st July 2012, 04:20 PM   #256
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Preamp ideas for F5
that hypothesis is tried long ago
there are myriad of much better solutions , for preamp duty
but - if using it as is for preamp amuses you , that's also completely valid reason
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st July 2012, 05:02 PM   #257
Preamp ideas for F5
Thank you Zen Mod. Case closed.
Old 22nd July 2012, 07:18 PM   #258
Preamp ideas for F5
There was an earlier request for a headphone ACA. I have a simple and painless method to do so for any amp devoid of a headphone port. Please visit the last 4 threads in Headphone Systems entitled "Does anyone make their own headphones". Best
Old 22nd July 2012, 08:06 PM   #259
Banned
Yeah, the ACA#1 looks suitable for headphone amp. Actually, it seems also suitable for power amplifiers (strictly with high impedance speakers), but may be not. I'm curious myself with this topology. I cannot find anything wrong except visually, i.e. use of N-N that forces feedback resistor to connect input to output.
I'm building the ACA#1 with IRFP460 (which gives better simulated performance than IRFP240), starting today and hope to be completed tomorrow (today I have finished the chassis, PCB, simulation and parts gathering). Unfortunately this is for a friend so I will not be able to review its performance (It needs time to review the performance as I guess there will be some kind of "boring effect", even tho the current drive is good).
Old 3rd August 2012, 12:20 AM   #260
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Pardon me for being dense, but do I understand correctly that some people are suggesting the BA3 input board for a line-stage preamp?
Preamp ideas for F5Hide this!Advertise here!
Discrete Op Amp Ideas for a Preamp analog_guy Solid State 16 16th June 2007 04:18 AM
Preamp signal wiring ideas ? gurevise Tubes / Valves 7 30th January 2007 07:19 PM
Ideas for preamp box design paulspencer Analog Line Level 5 26th August 2006 06:46 PM
Ideas for using one ECL82 in a preamp Tyimo Tubes / Valves 17 6th May 2006 05:35 AM
