Preamp ideas for F5
Preamp ideas for F5
Old 29th March 2012, 12:51 PM   #121
juma is offline juma  Germany
juma's Avatar
Originally Posted by evanc View Post
...In the schematic the source of the 2sk170 is hooked throughout the potentiometer to the drain of the 2sj74...
Hi Evan,
your interpretation of the schematic is wrong (JFETs are drawn as if vertically mirrored). P1 is attached to Sources of both JFETs. In order to work, P-channel JFET needs its Drain to be more negative than its Source (and vice-versa for N-channel JFETs).
Google for : "Erno Borbely JFET frontiers"
It's two-part article that will help you understand and use JFETs
Old 29th March 2012, 02:33 PM   #122
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Preamp ideas for F5
Excellent thanks for the explanation...I will build this this weekend...Thanks again..Evan
http://www.evancotler.com
Old 29th March 2012, 05:50 PM   #123
Preamp ideas for F5
OK stupid question #2. Will this circuit run on 10vdc.? Could i decrease the values of r4 r5 r6 and r7 to drop less voltage there?
Old 29th March 2012, 07:08 PM   #124
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Preamp ideas for F5
do you like breathing through just one nostril ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th March 2012, 07:58 PM   #125
Preamp ideas for F5
I'll take that as a no...I said it was a novice/stupid question. My idea was to use the power supply that is all ready in the chassis. If this bit doesn't work out then oh well the ipad will only **** off neighbors two houses away instead of three....
Old 29th March 2012, 08:20 PM   #126
juma's Avatar
...Will this circuit run on 10vdc.? Could i decrease the values of r4 r5 r6 and r7 to drop less voltage there?
I suppose you mean +/-10V ? You have to precisely describe the circumstances...
As you see, the F5 runs on approximately +/-24V. That's why there are 7812 and 7912 regs to lower the voltage to +/-12V. If you want to use the preamp in the same box with F5 why would you want to supply the preamp with "10V"?
Please be more descriptive if you expect meaningful answers...
Old 29th March 2012, 08:29 PM   #127
Preamp ideas for F5
Sorry for being too brief, doesn't everyone know all about my system and what I want....? I am thinking about your preamp in the chassis with my DCB1. That runs on +/- 10 volts. I only want to amplify one source that is why I am not thinking of the installing with F5. Anyway thanks for putting up with my lack of knowledge. I'm trying, Really I am....
Old 29th March 2012, 08:49 PM   #128
juma's Avatar
OK, don't worry.
You can use the preamp with +/-10V PS.
Lower R6,R7 to 47-68R (in order to get 10-15mA through Q3/Q4)
Omit the 7812/7912 regs. Keep the RC filters (R1, R10, C1-C4).
Old 29th March 2012, 08:54 PM   #129
Preamp ideas for F5
Nice...Thanks. Neighbors watch out....
Old 29th March 2012, 08:54 PM   #130
Zen Mod's Avatar
Preamp ideas for F5
extremely fine furniture
Preamp ideas for F5Hide this!Advertise here!
Discrete Op Amp Ideas for a Preamp analog_guy Solid State 16 16th June 2007 04:18 AM
Preamp signal wiring ideas ? gurevise Tubes / Valves 7 30th January 2007 07:19 PM
Ideas for preamp box design paulspencer Analog Line Level 5 26th August 2006 06:46 PM
Ideas for using one ECL82 in a preamp Tyimo Tubes / Valves 17 6th May 2006 05:35 AM
