#101 |
Juma, thinking about your bf862 pre and was wanderin what kind of spread you get with you fet matching. I woul dlike to drop them in my DCB1, but at anything more than about 10mA, i hav eto woory about heat and need degeneration, correct.
#102 |
Buzz, I bought 500 pcs. batch from Mouser and 90% of them are in 13-14 mA range. The rest is 1-2 mA higher or lower.
Since I don't like gate current, degeneration is mandatory (5-10R). I use them with Id of about 10mA at Vds of about 10V so heat is not a problem. Actually I didn't have a single failed BF862 with Pd of 150mW - for more you'd probably have to cool them. A small area of copper at the Gate is enough to keep them coll enough. Last edited by juma; 12th February 2012 at 10:44 PM. |
#103 |
Didn't read all the thread, but a 6sn7 aikido sounds great with the F5.
#104 |
Using juma's post 53rd schematic to draw a buffer with input selectors. Hope he don't mind
The size is 56 X 85 mm.I am curious that should I put each 0.1uF on the voltage rail near to the buffer? Or just one unit 0.1uF on the PSU is enough. 78L05 regulator feeding G6K-2P-5VDC relay with 1n4001, I doubting will this work nicely? ![]() PS: I am using SK-13D07 slider for selecting input. I wonder if the connections correct compare to datasheet
~.~ Last edited by chchyong89; 23rd February 2012 at 10:27 AM. |
#105 |
^do you really need the input buffer? ;p The 2sk170 input has high enough input impedance.
#106 |
Hi fellow Diyer's
need a little help from my friends' I have been using my F5 for quite some time now using a SONY digital processor as preamp. Sounds very good I'm happy with the set-up. but would like to try the sound of the TUBE , for cheap. Just to have a taste of what the buzz is all about, I bought a 2nd hand Little dot MK III pre /headphone amp .which is nice using it as a headphone amp. I have measure the DC offset of the tube amp and it's in mV so I think it's fine to connect it to F5 just to quickly check. I was happy I like what I'm hearing. The next listening session, very eagerly, I turned everything ON, CD player, Tube pre and F5 in that order, I forgot that I need to let the Tube pre to warm-up first and stabilized. DISASTER... in a split second my Fostex BLH speaker fried really good!! cone is stuck and voice coil open circuit. Whaaa!!! Can anybody in the cummunity help me with my problem? I like this tube pre and F5 combination but don't know if it's alright / or a SIN to put a coupling cap infront of F5? what value? Any help is appreciated. Thank, Reytnz |
#107 |
#108 |
#110 |
Another idea for a nice preamp suitable to drive F5 (post #55 and onwards) :
If You Don't Have a SIT, Fake It... When used to drive F5, C4can be 1uF and R9=1Meg. For C3 (10uF) I successfully used SMD (0603) COG cap. Last edited by juma; 25th March 2012 at 01:08 PM. |
| Discrete Op Amp Ideas for a Preamp | analog_guy | Solid State | 16 | 16th June 2007 04:18 AM |
| Preamp signal wiring ideas ? | gurevise | Tubes / Valves | 7 | 30th January 2007 07:19 PM |
| Ideas for preamp box design | paulspencer | Analog Line Level | 5 | 26th August 2006 06:46 PM |
| Ideas for using one ECL82 in a preamp | Tyimo | Tubes / Valves | 17 | 6th May 2006 05:35 AM |
| Page generated in 0.16469 seconds (100.00% PHP - 0% MySQL) with 10 queries |
