Old 5th July 2008, 03:09 PM   #1
Default Check idle current on PA 7 Nakamichi
Hello to every sound lovers,
i'm a new happy owner of a Nakamichi PA7. I heard that sometime idle current are increasing and can make damage. So, before bringing my amplifier to a technical station i thought that i could have an idea by measuring the amplifier consuption on the main cable.
Do you think it's a good idea and what could be the consuption of the pa7 WITH 0volt on the input ?
Thanks,
Laurent.
Old 5th July 2008, 03:40 PM   #2
analog_sa's Avatar
Default Re: Check idle current on PA 7 Nakamichi
Not very good. One channel may be up, while the other is down and the total consumption is still normal. Just open it and measure the voltage drops on the emitter resistors. If it's similar to the Threshold amps you would expect around 100mA per transistor or maybe someone can provide accurate values.
Here is the relevant thread
Old 5th July 2008, 10:35 PM   #3
The one and only
Nelson Pass's Avatar
Put your hands on the heat sinks. If you can hold them there for
10 seconds or so, then it's just right.
Old 7th July 2008, 09:19 AM   #4
MadMutt is offline MadMutt  Australia
To suit PA7 and PA7e.
From service manual.
Enjoy
PS, this 100k/1000pixels limit is really starting to wee wee me off big time..........
Old 19th January 2009, 07:03 PM   #5
jiky657 is offline jiky657  Germany
@MadMutt
Would it be possible to get a copy of the PA7e service manual?
My emailaddress is me@stairweb.de
Thanks a lot!
Markus
Old 19th January 2009, 10:23 PM   #6
Thanks to everybody.
My PA7 is now working with Rega Planar 3/RB 300 + DL103, Préamp Naka CA5E, Ditton 66 monitor rewired and Terminator 2 cable for loudspeakers.
Any advice ?
Best regards to all,
Laurent.
What's the Idle Current of the F5 Power Amp NV&H Pass Labs 56 3rd February 2010 10:56 AM
Idle current adjustment for NAD gvelim Solid State 0 5th August 2008 03:56 AM
idle current for bryston 4B Danielll Solid State 2 3rd October 2005 05:25 PM
chip amp idle current maylar Chip Amps 2 29th December 2004 03:25 PM
SMPS Idle Current cm961 Parts 2 20th February 2004 05:56 AM
Page generated in 0.09191 seconds (78.69% PHP - 21.31% MySQL) with 11 queries
