Old 3rd July 2008, 02:35 PM   #11
cfcubed is offline cfcubed  United States
cfcubed's Avatar
Wanted to add my thanks for the article too... Being new to this, articles like that sure help.
Wonder if the "Our meters don’t go to zero." bit is akin to the Spinal Tap volume 11 bit
Old 3rd July 2008, 04:17 PM   #12
MEH is offline MEH  United States
Is there a general principle that can be stated about the relative quality of generating overall bias current X through n devices vs. through m devices where n < m?
Old 3rd July 2008, 04:39 PM   #13
EUVL is offline EUVL  Europe
I found Fig.4 particularly interesting, and presume they showed the distortion of a single pair of complementary devices at the said bias current.
I wonder what the distortion would look like if the same bias current is shared between say 4 pairs of the same devices in parallel, each device only take 1/4 of the bias current as in Fig.4.
Would you perhaps care to comment on this ?
Patrick
Old 3rd July 2008, 07:46 PM   #14
Hey! That's my question!
Old 3rd July 2008, 09:07 PM   #15
The one and only
Nelson Pass's Avatar
This question is commonly asked. Certainly the performance is
not identical for both cases, but there is a cancellation factor.
With parallel devices the transconductance as a whole goes up,
lowering the distortion because the variation per device is lower
by virtue of sharing the current.
At the same time, if the bias is divided between devices, the
distortion per device goes up.
The two effects do not give an exact cancellation, but it's close
enough that for most applications you can decide on the number
of parallel devices based on dissipation needs.
One factor that tends to favor parallel devices is that the
total bias dissipation can be larger even for the same size heat
sink, since there's less aggregate thermal resistance from the
junctions to the sink.
Old 3rd July 2008, 09:09 PM   #16
The one and only
Exactly where it came from.
Old 3rd July 2008, 09:12 PM   #17
> The two effects do not give an exact cancellation, but it's close enough that for most applications you can decide on the number of parallel devices based on dissipation needs.
Perhaps the distortion level is comparable, but how about the spectrum -- does the ratio between say 2nd, 3rd, 4th remain largerly the same, or do they shift one way or another ?
Patrick
Old 3rd July 2008, 09:52 PM   #18
Vix is offline Vix  Yugoslavia
Vix's Avatar
"Klunk!" -Your amplifier has just left class A operation! Consequently, small aliens will invade the transistors in your amp, generating distortion. Hence you will experience an instant decrease of sound quality, depriving you of listening pleasures, which may have side effects, such as insomnia. Consequently, you will have only two choices. First, you may turn down the volume (that you don't want), or, burn mo' power, to keep the green aliens away. If this statement does not make any sense to you, please go back to post nr.1 of this thread and read the paper. "Klunk"!
No, seriously, nice paper. By the way, if we connect more devices parallel, the capacitance also increases, making the output more difficult to drive?
Old 3rd July 2008, 10:17 PM   #19
Manu is offline Manu  Europe
Manu's Avatar
Mr. Pass, dear Papa,
referring to page 7, you suggest a ccs as best SE Bias for PP topology. What would you advocate instead of a Res to V- solution ...?
Manu
Old 3rd July 2008, 10:31 PM   #20
The one and only
The resistor works fine as long as the supply isn't too noisy.
Reading Leaving Class A . . . Babowana Pass Labs 11 4th October 2009 02:09 AM
Leaving D.I.Y everything must go sale...... exurbia Swap Meet 36 15th October 2008 04:42 AM
bg and suggestions of leaving the amp on jarthel Parts 3 29th June 2007 02:16 AM
Leaving X-former powered up Wynand Power Supplies 4 16th May 2006 02:07 AM
Leaving. fdegrove Everything Else 23 2nd December 2002 09:36 PM
Page generated in 0.10880 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
