just made Aleph-3, just made Aleph-3, - diyAudio
just made Aleph-3,
just made Aleph-3,
Old 2nd July 2008, 02:24 AM   #1
space2000 is offline space2000  Singapore
Default just made Aleph-3,
This is my first class A amp i ever build. so pls try to understand this.
i just made Aleph-3. now time to assemble it properly. showing my msy table...ha...
i had used other mthod to bring down temp. first i used huge heat sink, put 6 mosfets each. also attached thick copper plate at the join to have low resistence. also it is working very well for mosfest internal tharmal to be lower. i touched on the mosfest after svrl hrs, it is slightly worm but not hoot at all...i believe this way the mosfest life will be much more longer. i also used fan to cooling down the copper plate and heat sink...this way my temp only stay on arround 40 to 42c....at my 32 deg amb temp (today rate).
amp is working very very well. i am now thinking to assemble it properly. i am still operating it for checking if there is any problem arise.
i have question about GND connection. i made star GND.
is it all this will go to star GND indivisualy?
R101, R106, R137
if you have any cooments on it pls write. thanks for help.
michael
Old 2nd July 2008, 02:30 AM   #2
Default here is the circuit design
hi,
here is the circuit design.
thank you
Old 27th July 2008, 01:12 PM   #3
Default finally assembled aleph-3
hi,
i just assembled aleph-3- 30w onto the heat sink and tested good sound quality.
now i have set to 45wrms into 8ohms. can i add more mosfets at output for this circuit to have 60w or more?
Here is the picture. hope for comments.
fully hand made.
best regards
michael
Old 27th July 2008, 01:38 PM   #4
guitvinny is offline guitvinny  Canada
guitvinny's Avatar
Great for you !
If you want to clean this wiring you should check the site of BrianGT, he made some very nice PCB for Aleph Mini & 30.
Have fun !
just made Aleph-3,Hide this!Advertise here!
Aleph AC current gain made easy darian Pass Labs 8 13th September 2007 05:52 PM
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 02:45 PM
Aleph 5 made in France Phill Pass Labs 3 22nd December 2005 12:01 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 01:29 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
