Old 30th June 2008, 01:08 AM   #1
Default Just finished a Lightly balanced Zen
I started this project in the winter of 2007. After having read through the Zen articles I wanted to start with the Zenlite, and do the balanced one since I had already done the Bosoz.
In this amp there are some recycled parts. All the sockets have been recycled from old lamps. The power switch is a recycled switch that was installed in our house in 1957.
After having built the first channel it was time to find light bulbs. This should probably have been done first, because I could only find 40W and 60W bulbs at the local store. By accident I found 100W bulbs at another local store this winter, and the project could continue.
I built the circuit in figure 16 with no changes. The power supply has a 500VA 40-0-40 transformer and the suggested CLC (25000uF - 5mH - 25003uF) unregulated supply, giving ~60V.
Each MOSFET in the amp has two bulbs in parallell for bias current, giving ~2A to each MOSFET.
The amp has been in use a couple of weeks driving the mid/high section of my speakers, and I think it is absolutely gorgeous. And it is dead silent with absolutely no audible hum/noise on 100dB sensitive speakers.
I have not done anything to make it look like it deserves. Wooden box for the power supply with the heat sink attached to one side. Heatsink is ~0.4C/W. I have no trouble holding my hand on it after 2 hours.
Old 30th June 2008, 01:09 AM   #2
The power switch...
Old 30th June 2008, 01:56 AM   #3
Paper mache horn fabricator
carpenter's Avatar
switch to heat-lamps for winter use!
Thanks for reviewing the sound quality. I've always wondered how that fellow performed.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 30th June 2008, 09:54 AM   #4
Magura is offline Magura  Denmark
Magura's Avatar
Thats what it's all about!
Make an amp, see what it's good for, perhaps tweak it to adapt it a bit, gain experience, make another amp.........
That is according to my opinion, best done by not wasting too much time on shiny boxes and searching for butique parts.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 30th June 2008, 06:16 PM   #5
carpenter's Avatar
Magura
Aaaaah, but I like those pretty boxes, too...
Old 30th June 2008, 07:03 PM   #6
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
but - you don't need amps now , when you have Spice ..... to play with .....
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 30th June 2008, 08:42 PM   #7
carpenter's Avatar
Stepping off-topic for a second. (sorry)
You know, you really did hit the nail on the head... With regards to the creative process, my brain doesn't care whether I'm fabricating an amp, or designing (OK, grappling with in my case) a new slant on Nelson's schematics. As long as I'm listening to something I've built in the past, the future can wait while I play in the spice-box.
BTW Choky, thanks for offering up that LUAX schematic the other day. I'm learning a bunch about CCS layout.
Gold Lion KT88 (lightly used, matched pair) n_maher Swap Meet 1 26th May 2009 06:42 PM
Genelex Gold Lion KT88s (reissue version) (matched quad, lightly used) n_maher Swap Meet 8 10th September 2008 06:01 PM
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 05:27 PM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Page generated in 0.10393 seconds (79.47% PHP - 20.53% MySQL) with 11 queries
