I saw a post re scalability of the Alephs, a light bulb went off, I came across locally & bought two of BrianGTs original Aleph 30 “kits” (pcbs, parts and matched output devices).
I’d like to use the 2 kits to make an Aleph “60”. For my 84 dB, 3.1 ohm speakers, the target load is 3 ohms, power into that load min 60 watts, 100 would be a little better. They will preferably be monoblocks, other than that, I’m open. I guess I could make two Aleph 30 amps, and “parallel” them, which would allow future flexibility, but require 2 more cases . . As the speakers drop to 3.1 ohms, and it should sound better, I want to bias them as high as possible. It helps a little that I’m in the same city as Conrad. I searched on aleph 30 bias, but got 1430 hits . . Has anyone done something like this? How are the rail voltages, transformers and current calculated? Thank you |
#2 |
Otto-man,
do a search for the Volks(wagen)-60. ![]() 25Vac transformers and biased to 2-1/4 amp, calculate the dissipation/ch yourself to size the trannie. |
#3 |
hi,
as i have build it. so i know little bit about it. pls check the attachment here already stated to changing the watts and how much current do you require. i hope you can find here. i am using 10 ampire 29-0-29v..amp output is 30w for now as i am still learning about it. heat sink need to be very big. mine gets alst cound on high volume 46c, amban is 30c. i think the temp is ok....not really bad after 7hers of operating. best regards michael |
#4 |
Jacco
I searched on Volks 60 and didn't see much, finding more searching on the Aleph 60 . . I saw that Grey has said that "the Volksamp 60 is basically an Aleph 2 running at lower bias". Not that bias is the main criteria of good sound, but it should help with that, with the low ohms. But it seems the Aleph 60 should be my "model". > 25 Vac transformers and biased to 2-1/4 amp What % current gain did you assume to arrive at those values? space2000 Your schematic says its for the Aleph 3; I may be wrong but at a quick glance it appears more complex than BrianGT's Aleph 30? To make a 60 from the 30, apart from doubling the output devices and heatsinks (or more if current gain is increased to say 65%), and larger transformers - what component values need to change? Thanks |
#5 |
Here's one in my lingo with a main numbers list of the various Aleph models, 1st one that pops up when i do a Goggle dive.
You'll find identical lists at several home pages of English speaking Aleph builders. (whenever i really need to find something at Gurgle i run through a dozen different language versions) Numbers The Aleph2 has both different rail voltage levels and is biased higher. |
#6 |
Jacco
Thanks for that link, I thought you'd suggested searching just here at diyaudio . . Btw, I saw you have esl 63s ~ I have Apogee hybrid ribbons . . To keep the rail voltages around 2*25, but bias the 60 to the level of the Aleph 2, what is the formula for amps bias and the traffo's VA? Can anyone say if/ which component values in BrianGT's Aleph 30 would need to change? Thanks |
#7 |
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#8 |
Thanks ZM!
{The resistor that affects Ac current gain (R21 in the Aleph 2); on BrianGT's Aleph 30 BoM - doesn't appear to be flagged, I'll have to track it down . . } In Aleph-Power.xls, puzzled that doubling the number of fets makes *no difference to power at any ohms |
#9 | ||
number of outputs will have influence on damping factor , open loop gain and - naturally - on exact dissipation per device
#10 |
Thanks Zen Mod
the terms in Williams spreadsheet? eg Transformer wattage - factor 2/ 3 /4 I *think the explanation of factor 2 is "because the 50% current gain means that the current source delivers 50% of the peak current at idle" If Ac current gain is 65%, what is the factor: 3 /4? |
| Aleph 4 - Simulation Results from "Circuitmaker" | tiefbassuebertr | Pass Labs | 0 | 17th July 2009 11:53 PM |
| The Aleph "Ge" - Germanium Preamplifer | Bakmeel | Pass Labs | 5 | 9th June 2009 11:02 PM |
| Aleph-X smaal EU "small-parts" groupbuy | Sander | Group Buys | 3 | 3rd December 2008 11:48 AM |
| What are "good" sounding resistors for my aleph p | Shaun Perez | Pass Labs | 6 | 29th July 2003 01:46 PM |
| Aleph "L" Stepped attenuator on the input or the output? | Mark A. Gulbrandsen | Pass Labs | 6 | 13th March 2003 12:21 AM |
| Page generated in 0.11871 seconds (82.32% PHP - 17.68% MySQL) with 11 queries |
