#11 |
Hey,
I was hoping someone could answer my question relating to matched transistors, which in my research has come up as something that is fairly important: http://www.passdiy.com/pdf/mos.pdf Unfortunately, the only test equipment I have is a multimeter. If anyone knows where I might be able to find matched transistors for this project, it would be greatly helpful. Also, Brian of Chipamp.com got back to my email and mentioned that someone here might have a copy of the Aleph service manual, which could clarify some things for me. Anyone know where I could get a copy? Thanks |
#12 | |
But didn't you want to build a mini-A ? As far as I recall, there is only one fet per bank, so no need for matching. Just grab the first TO-247 size mosfets you see on your bench, and you're good to go. All you need to consider, is that you need 2 P-channels and 2 N-channels. Those could be anything from IRFP044 and all the way up to IRFP450, the P-channels are a little more limited in range, as they stop at IRFP9240, but again any TO-247 P-channel will do, so it's just gotta be IRFP9xxx. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#13 |
Here is the parts list for Brian's PCbs:
http://www.chipamp.com/diyaudio/mini-A.xls In the notes it says they should be matched for VGS. |
#14 |
Hello Ryan, you can order the PCB for make an Aleph 30 here:
http://www.chipamp.com/orders.shtml There's not a guide but an excel sheet where you find all the component end the corrispective part on the pcb when you solder. http://www.chipamp.com/diyaudio/mini-A.xls You can match the IRFP240 and the IRF9610. If you have a problem, in this forum someone sell the mosfet already matched (talk with user Tarrasque) |
| Wanting to build a mic mixer | DeadSpeaker | Everything Else | 1 | 27th October 2007 02:03 PM |
| Technology Student Wanting To Build Full Range System | morfius | Full Range | 46 | 12th September 2007 09:09 AM |
| Newbie, wanting to build Amp | PaulHilgeman | Solid State | 3 | 8th January 2003 02:24 AM |
| Wanting to build an hdtv tuner | Shaun Perez | Digital Source | 13 | 31st October 2002 04:03 PM |
| Page generated in 0.08033 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
