Old 16th March 2003, 11:25 AM   #1
Default balanced x-Preamp
This is a variation of my sym. Headphoneamp
sym. Headphone amp
used as preamp.
You could use it asym. and sym.
The output should be used balanced for best perfomance.
Not build yet, but should work.
Powerdissipation is 5W each channel. You must use
a regulated supply. Have fun.
Andreas
Old 16th March 2003, 11:27 AM   #2
Default forgot attachment!
Here is it.
Old 17th March 2003, 07:06 AM   #3
Default Nobody intrested?
Seems that nobody is intrested in this design.
I will repost when prototyp is done.
Andreas
Old 17th March 2003, 06:28 PM   #4
loovet is offline loovet  Sweden
I do find your schematic interesting.
How about this PCB layout?
/loovet
Old 17th March 2003, 06:32 PM   #5
Default Zip file doesn`t download!
Hi loovet,
couldnīt download your file.
Andreas
Old 17th March 2003, 06:52 PM   #6
Default Re: Zip file doesn`t download!
Originally posted by Orgonom
Hi loovet,
Andreas
I can see that the file have been downloade at least 9 times.
Any one else who got the same problem?
If you still can't download the file i can e-mail you.
/loovet
Old 17th March 2003, 07:20 PM   #7
I got it. Thanks for your work.
But could get it only with MS Explorer and not with NS 4.7 !???
To your PCB:
Take a look at my headphoneamp from the other tread. I put the mosfets back to back. Guess why?
Andreas
Old 17th March 2003, 07:33 PM   #8
To your PCB:
Andreas
The fets work more symetric if they have the same temp?
/loovet
Old 17th March 2003, 07:49 PM   #9
as the transductanz vary with the temp - Yes.
Andreas
Old 27th March 2003, 02:21 PM   #10
Can this X-Preamp be made to work just as well with Pchannel IRF devices in place of the ZVP3306 (since I am not able to obtain them)? What are the changes that need to be incorporated? Can we have a schematic of this as well? Perhaps, this will generate more interest from everyone to couple this preamp with the Aleph-X amps.
Sam
balanced tube preamp Freddie Tubes / Valves 29 18th March 2010 09:50 AM
Preamp with balanced outputs miguel2 Chip Amps 9 5th May 2004 02:19 PM
balanced preamp question bonsai171 Solid State 8 17th April 2004 03:24 AM
Balanced Mic Preamp AudioFreak Solid State 14 21st July 2003 03:21 PM
Page generated in 0.09957 seconds (77.98% PHP - 22.02% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
