#11 |
hi thanks for help.
here is the circuit. i followed same as it is. power supply is 29vdc. |
#12 |
hi,
can i add more then three pair of output mosfets? as it is only 30w using three pair of mosfets. if i want to get 100w then i will require 7 more pair. also the power supply must be 0.5 X 20 =10 ampaire. thank you. |
#13 |
As you increase voltage and current, the power output will increase. It is necessary to add additional Mosfets to dissipate the increased power levels across more Mosfets as to not overload those output devices.
On your other question... When measuring the output voltage apply a sine wave of a known voltage and measure it's amplitude at the output. You will need a signal generator and a scope. A simple singal generator can be made pretty easily. Perhaps other forum members here have a better idea, but that's how I've done it. -David |
| Aleph 3 pcb question. | timcatn | Pass Labs | 0 | 19th April 2007 07:34 AM |
| Aleph P 1.7 / Aleph 1.2 Balanced IC Question | SRMcGee | Pass Labs | 2 | 25th March 2007 04:16 PM |
| Aleph P1.7 question | AndrejM | Pass Labs | 16 | 2nd March 2005 08:15 PM |
| Aleph 0s question | moe29 | Pass Labs | 3 | 14th December 2002 04:06 AM |
| Aleph 5 ps question | protos | Pass Labs | 8 | 17th July 2002 11:21 AM |
