Audio Virtues of JFET Transconductance Amplifiers
Old 16th May 2018, 05:15 PM   #41
EUVL is offline EUVL  Europe
Yes, I also thought the Pioneer SL was very clever, and really good sounding.
That is from someone who builds almost exclusively with FETs.
As I was trying to stay with the original Pioneer circuit, I did not want to change it too much.
But I agree that the current mirror can be improved, at the expense of complexity.
Having said that you can see in our measurements how low the distortion, especially H2 is.
And with the BJT input I can trim DC offset at the CCS bias :
The Pioneer Super Linear Circuit
The main circuit remains completely symmetrical.
And DC is stable to mV's after trimming.
I also have on the drawing board a pure transconductance headphone amp based on the SL.
i.e. totally current drive, no global feedback, (and of course no voltage feedback).
The bug is of course the actual voltage gain depends on and varies with the load impedance.
So only of any use for planar magnetic headphones.
Shall build proto in a few months, just out of curiosity.
Patrick
xen-audio.com
Old 16th May 2018, 05:26 PM   #42
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
some things never change!
but i still want to know how he cascodes himself!
hmmm .... maybe i don't
mlloyd1
Originally Posted by Nelson Pass View Post
Yes, Jam admires himself in the current mirror every morning....
Old 16th May 2018, 05:38 PM   #43
jam is offline jam  United States
jam's Avatar
Big Brother is watching you Michael.........................
Old 16th May 2018, 05:52 PM   #44
jam's Avatar
Hi Patrick,
Surprising you mentioned a pure transconductance amplifer, I have tried this with excellent results but you are correct in the fact that you need a load with a flat impedance. With a current multiplying mirror it can be done.
This is what I used for the mirror, there are more complex versions but this worked just fine and you can parallel stages (within reason) to get the required current.
Jam
Old 16th May 2018, 05:55 PM   #45
lineup is offline lineup  Sweden
lineup's Avatar
Patrick
Most times an output buffer is used in transconductance ampllifiers.
Otherwise the output voltage is load dependent.
Several transconductance Chips have such buffer transistors onboard one can use.
lineup
Old 16th May 2018, 06:01 PM   #46
A transconductance amp by definition is voltage in current out.
And output current is proportional to input voltage.
And negative loop feedback is not necessary, as in Jam's example.
The minute one hangs a buffer at the output, it becomes a CFA.
i.e. the output voltage is porportional to input voltage, irrespective of load impedance.
Patrick
xen-audio.com
Audio Virtues of JFET Transconductance AmplifiersHide this!Advertise here!
Can I use the 2N5484 jfet diff pair in an audio amplifier front end? carpenter Pass Labs 27 28th March 2009 12:55 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 03:08 AM
Bestow upon me the virtues of MM vs. MC eeka chu Analogue Source 17 16th November 2005 07:45 AM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
IC audio amplifiers jteef Solid State 8 21st July 2001 03:14 PM
