Audio Virtues of JFET Transconductance Amplifiers
Old 15th May 2018, 07:43 PM   #31
jam is offline jam  United States
jam's Avatar
Old 15th May 2018, 09:44 PM   #32
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
(wanna pcb , to make XA25 killer ?)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th May 2018, 11:13 PM   #33
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Yes, Jam admires himself in the current mirror every morning....
Old 16th May 2018, 01:00 AM   #34
jam's Avatar
Old 16th May 2018, 06:37 AM   #35
lineup is offline lineup  Sweden
lineup's Avatar
Originally Posted by jam View Post
Everyone seems to forget about the Early Effect...............
Eliminating the Early effect in the... (PDF Download Available)
Jam
I dont understand what can be done to eliminate early effect.
That paper does not say.
It just shows a Wilson current mirror at the end.
lineup
Old 16th May 2018, 07:08 AM   #36
jam's Avatar
An enhanced Wilson (4 transistor goes some way to reduce the Early Effect) but this situation can be reduced further by adding helper transistors (base current compensation). This is particularity helpful if you are using a Widlar Mirror.
Adding resistors to the emitters of the upper mirrors usually helps the accuracy of the mirror.
Cascoding can also help by reducing heating of the mirror transistors.
If you are using transistors of the same lot numbers I find that beta matching is usually less important, besides you could add a trim pot to balance the mirror in a complementary circuit to zero the dc offset, but I digress.......
Jam
Old 16th May 2018, 07:39 AM   #37
Zen Mod's Avatar
oh yeah , we know that Jam likes mirrors , current or past , whatever
Old 16th May 2018, 10:17 AM   #38
EUVL is offline EUVL  Europe
Do not agree.
I bought recently 200 each 2SC3324BL and 2SA1312BL.
Supposedly already preselected.
hfe is all over the place, and almost no N-P match.
The Pioneer Super Linear Circuit
See PDF in Post#1, also post #127, 132.
For me a must. I have not been able to do without.
But then I also do not have any NFB.
Patrick
xen-audio.com
Old 16th May 2018, 03:20 PM   #39
jam's Avatar
Hi Patrick,
I have to admit I use feedback in my circuit. I have compared the circuit I use with matched transistors and without and I don't see much difference on the AP
analyzer, maybe a slight reduction in second harmonic but not much else.
I agree that without feedback matching is much more important but if you are direct coupled without a servo you still have to trim dc offset somehow.
I find that matching the input fets I use much more important.
Nice headphone amplifier design.
Old 16th May 2018, 03:33 PM   #40
jam's Avatar
Patrick,
Great circuit that Pioneer promoted (Their new new stuff is not nearly as good).
So how about taking the front end up a notch ..................... Ignore the feedback.
Jam
File Type: png 1654634_413491055452609_441026644_o.png (79.0 KB, 89 views)
Audio Virtues of JFET Transconductance AmplifiersHide this!Advertise here!
Can I use the 2N5484 jfet diff pair in an audio amplifier front end? carpenter Pass Labs 27 28th March 2009 12:55 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 03:08 AM
Bestow upon me the virtues of MM vs. MC eeka chu Analogue Source 17 16th November 2005 07:45 AM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
IC audio amplifiers jteef Solid State 8 21st July 2001 03:14 PM
