Audio Virtues of JFET Transconductance Amplifiers
Old 15th May 2018, 03:51 PM   #21
lineup is offline lineup  Sweden
lineup's Avatar
This is a circuit that I think works.
But I have to try it when I get home some more transistors.
It takes 18 of BC560C and BC550C.
It is a VCA. Voltage Controlled Amplifier.
At the input is a divider that divides with roughly 44.
The small resulting voltage is put to input pair.
The current difference is transported to the output, and put across a 10k resistor.
At the output is a buffer transistor.
Max bias input is like 1mA and so is 0.5mA at each transistor.
P2 potentiometer is to regulate the volume with the bias current.
P1 is for adjust eventual output offset.
I might need to adjust some values when I test it at my experimentboard.
lineup
Old 15th May 2018, 05:25 PM   #22
jam is offline jam  United States
jam's Avatar
Lineup,
It has been ten years...................since this thread was active......good to have you back lineup................Mr.Pass probably thinks I am a wildman too.
Jam
Old 15th May 2018, 05:34 PM   #23
jam's Avatar
Just for grins and giggles.......................
Old 15th May 2018, 05:36 PM   #24
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Originally Posted by EUVL View Post
A question for Nelson :
Suppose one builds a balanced version, but the two halves are not 100.0000000% well matched.
i.e. the output of one phase is not exactly -1.000000000x of the other.
Since both current outputs are connected to a single load, where the hell of the difference in the two currents should go to ?
The are absorbed by the net value of impedances at the output:
1) intrinsic output Z of the open loop circuit (always less than infinite)
2) output z due to negative feedback
3) load impedance
Old 15th May 2018, 06:29 PM   #25
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
current mirrors are for Sissies
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th May 2018, 06:34 PM   #26
stocktrader200 is offline stocktrader200  Canada
match all transistors to have a Hfe of 200 to 250. Just make sure that all are the same, then the distortion will be lowest.
Old 15th May 2018, 06:58 PM   #27
jam's Avatar
Zen Mod.
Guess that makes me one.......................
Old 15th May 2018, 07:03 PM   #28
lineup's Avatar
Is the hFE more important than the b-e voltage?
In this case.
lineup
Old 15th May 2018, 07:09 PM   #29
jam's Avatar
Everyone seems to forget about the Early Effect...............
Eliminating the Early effect in the... (PDF Download Available)
Jam
Old 15th May 2018, 07:39 PM   #30
Zen Mod's Avatar
not Moi , Bubba
F4 Beast Builders
Audio Virtues of JFET Transconductance AmplifiersHide this!Advertise here!
Can I use the 2N5484 jfet diff pair in an audio amplifier front end? carpenter Pass Labs 27 28th March 2009 12:55 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 03:08 AM
Bestow upon me the virtues of MM vs. MC eeka chu Analogue Source 17 16th November 2005 07:45 AM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
IC audio amplifiers jteef Solid State 8 21st July 2001 03:14 PM
