B1 Buffer Preamp
B1 Buffer Preamp
Old 12th November 2008, 07:11 AM   #901
big1 is offline big1  Australia
Default Re: Re: Re: B1 born in the land of Oz
Originally posted by rabbitz
I meant "did". You had me going there as I'm partially disabled and tend to hit the wrong keys or type slower than the brain so I miss out on key words.
When I adjusted the offsets to about the same numerically (1.4mV), even though one was +ve and the other -ve, the rails were quite different. I'm trying to remember but it was something like +10.1V and -9.4V so I decided to keep the rail voltages the same and have and extra 1.3mV offset which is no problem.
Salas
The next one I build I'll try and get them closer, but hey, a few mV here or there is not going to upset me.
Hi
I have the Anthony Holton NXV200 amp and would like to build B1,where do you get the parts in oz?
Old 12th November 2008, 11:00 AM   #902
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
big1
I bought mine from diyAudio member Kovax in Croatia. Took about 12 days to arrive and work a treat.
http://www.diyaudio.com/forums/showt...hreadid=126566
No longer DIY active
Old 12th November 2008, 11:35 AM   #903
flg is offline flg  United States
flg's Avatar
Originally posted by Gooch
...I have another question I have an old Dell laptop power supply output is 20v DC that should work? Or should I get something at 18v DC?...
Your Dell charger is likely a fairly well regulated 19.5-20V or so. There will be almost no loading on it as it is likely 3A-6A rated. I would position it a good fisical distance away from the B1 as it will emit switching noise your systen will pick up. Also filter it better with some film caps.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 12th November 2008, 01:31 PM   #904
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
B1 Buffer Preamp
Try explaining it to the new bald headed boss
udailey, how did you know?!?! We just walked through a discussion of our December scheduling, which will be hectic. I asked him where my time off comes into the schedule because he has me involved in just about every hot project.
Everyone: I'll have some photos up soon of my B1 build as it progresses. I've already got the main board populated with caps, resistors, relays, etc.
I spent last night on getting my bridge rectifiers and caps populated...coming together nicely. This weekend will probably be spent in the garage drilling holes in the chassis on my drill press.
Old 12th November 2008, 01:40 PM   #905
Gooch is offline Gooch  United States
Gooch's Avatar
You most have one of those power supplies you pretty much nailed it. I order the parts I didn't have on hand now I have to come up with some type of chassis for it.
Thanks again for all the help
Old 13th November 2008, 02:21 AM   #906
jackinnj is offline jackinnj  United States
jackinnj's Avatar
B1 Buffer Preamp
My B1 is an ugly, Manhattan style version -- but does it perform quite nicely -- this is the THD% graph with only 18V -- when I run it at 32V the THD% averages about 0.00066%
Old 13th November 2008, 02:34 AM   #907
flg's Avatar
You most have one of those power supplies you pretty much nailed it...
I might have a few around here... I used to work in the off Line switcher bis. Used to build protos and demos. You can find some that are 8-10A. Save those for a power amp
Now I play with DC-DC stuff. 12V to 1.2V Not much use except for putor stuff
Old 13th November 2008, 03:43 AM   #908
jackinnj's Avatar
B1 Buffer Preamp
You really don't want to use a switcher -- note that 1/2 VCC is injected onto the gate and any noise on the VCC node will degrade performance.
Old 13th November 2008, 08:13 AM   #909
Melon Head is offline Melon Head  Australia
Banned
Hi Everyone
I got my B1 buffer PCB with 4 matched JFETS today.
Has anyone else received theirs yet?
Old 13th November 2008, 08:43 AM   #910
steenoe is offline steenoe  Denmark
steenoe's Avatar
Thanks Guy's for you help appreciate it.
Cheers
Dave
It can run on a voltage up to 24V.
What you really ought to want, is a shuntreg
Here and onwards
It simply sounds crisp, transparent and very enjoyable.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
