B1 Buffer Preamp
B1 Buffer Preamp
Old 9th November 2008, 08:20 PM   #881
udailey is offline udailey  United States
Passive Aggressive
B1 Buffer Preamp
That makes sense. Thanks Increek.
Uriah
Old 10th November 2008, 01:56 AM   #882
jameshillj is offline jameshillj  Australia
Default pcb mods
Uriah,
If you were to move the C100,200 apart and shift R4 to one side of the Q100,101 so then can move the four Q's together (after turning the Q200,201 around) to get better tracking - just a small thing, but ...
Also, if you were to move the R102,202 gown closer to the Q's, then can shorten the pcb.
Alternatively, can add a simple zen type reg or a Cmultiplier to input power rail.
Old 10th November 2008, 02:33 AM   #883
Passive Aggressive
B1 Buffer Preamp
jh,
Thanks for your response and time.
I spent maybe 15 minutes trying to change the Q's around. The traces dont want to behave and let the leads of the Q's be accessible. If this were a 2 sided board it would be a cinch. I tried, instead of putting Q101 and Q201 face to face, to put Q101 and Q100 face to face but the same sort of problems pop up with traces needing two sides.
Making the board shorter will not help in this case as I am using some giant poly caps for C101 and C201. They are really what is restricting the size of the board. I would like to compare the sound of the large polys with many other 10uf caps because this board could really be tiny with the large electrolytics standing upright and the rest of the circuit pushed together a bit. Also if the 1ufs were tantalum or ceramic, but thats an experiment away.
Could you tell me about the cmultiplier and why I might want to use this?
Thanks jh,
Uriah
Old 10th November 2008, 03:11 AM   #884
These simple ccts are quite dependent on the quality of the supply -(better power supply, better sound) - can use smaller high quality caps like those poly's with a Cmx chosen for sound characteristics - few parts, big difference.
The humble little Cmx cct often will give a more pleasant result than some of the more sophisticated regulators, and so easy to try out. Suggest you give it a go - plenty room on pcb!!
Old 10th November 2008, 06:07 AM   #885
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Default B1 born in the land of Oz
Firstly, thanks to Nelson for this simple design and to Salas for his work on the modified capless split rail version. The one I built is based around the schematic that Salas provided.
Very easy build, doesn't come much more simple than this, and no problems experienced. The circuit is extremely quiet with no associated nasties. I wasn't too sure about no caps even though the previous buffer (BB) in this pre also had none, so I made the board large enough to allow for caps if required.
Upon firing up, the offsets were -3.1mV, +0.2mV and were adjusted to -2.7mV, +0.7mV via the trimpots on the power supply. With these offsets the power supply was doing 10.1V and never varied more than 0.04V during all the testing. Changing the offsets to equal values did cause the rails on the power supply to differ too much. The offsets and only varied 0.2mV during hours of testing and playing, so no caps were used. Matched pairs of 2SK170BL were used (thanks for them Kovax) and maybe would have better offset results if 4 were matched.... dunno.... but the offsets I have is fine.
The initial tests and listening was done with a 10K Alps RK27 as that's what was in the case and the sound was as expected.... very transparent, open, smooth, good dynamics and wide range, in other words, much better than a standard passive but with the good attributes that a passive can provide. The 10K pot was then changed over to a 20K Alps RK27 and the sound was not quite as good. Some of the dynamics were lost, bass seemed more recessed and not quite as open. So the 10K pot went back in as well as the wiper shunt resistor changed to 100K from 220K. This is where it has stayed. I have no idea if the sonic variation was due to the quality of the pots, but both are Alps RK27 motorised and about the same age.
It was tested in 3 systems and 2/3 performed extremely well with one not reaching the full potential on offer. I think the simpler the system, the better the performance with the B1 and has ended up in my office partnered with an AudioSector LM4780 (reduced gain) and some Vifa based nearfield monitors. The B1 is just what the doctor ordered in this system and has taken it to a new level.... plus no additional gain.... woohoo. For those with ChipAmps and simple speakers such as fullrange, I think the B1 could be the ticket to better sonics. The other system with great performance used a Anthony Holton NXV200 and a stand mounted 2-way using Vifa XT25TG / Scan Speak 18W8531... the NXV200 never sounded better.
There will be more of these made for sure as I can think of a couple of other uses for the B1 (and no GAIN.... great).
No longer DIY active
Old 10th November 2008, 06:09 AM   #886
rabbitz's Avatar
... and a closer view.
Old 10th November 2008, 06:25 AM   #887
pinkfloyd4ever is offline pinkfloyd4ever  United States
Default Re: B1 born in the land of Oz
Originally posted by rabbitz
............ Changing the offsets to equal values did cause the rails on the power supply to differ too much. The offsets and only varied 0.2mV during hours of testing and playing, so no caps were used........
I think you mean did NOT? might not be obvious to non-native(?) English speakers
Old 10th November 2008, 06:49 AM   #888
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
Nice one rabbitz. Congrats. I selected my 2SKs very closely, virtually identical. Your offsets are fine too.
Old 10th November 2008, 10:23 AM   #889
rabbitz's Avatar
Default Re: Re: B1 born in the land of Oz
I meant "did". You had me going there as I'm partially disabled and tend to hit the wrong keys or type slower than the brain so I miss out on key words.
When I adjusted the offsets to about the same numerically (1.4mV), even though one was +ve and the other -ve, the rails were quite different. I'm trying to remember but it was something like +10.1V and -9.4V so I decided to keep the rail voltages the same and have and extra 1.3mV offset which is no problem.
Salas
The next one I build I'll try and get them closer, but hey, a few mV here or there is not going to upset me.
Old 11th November 2008, 03:33 AM   #890
Gooch is offline Gooch  United States
Gooch's Avatar
Hello
I am putting together a parts list for the B1 to order from Digi-key
This should work for a basic volume control don't you think
http://search.digikey.com/scripts/Dk...ame=381N253-ND
Dave
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
