Old 27th October 2008, 07:46 AM   #811
Originally posted by Nelson Pass
Arrrrr... 'Tis a pitiful preamp that a few micro-amps cannot source,
sez I.
and there are few valve pre-amps with a recommended load impedance of less than 50k.
That is not an invitation to list ten valve pre-amps that can, it's just a statement of the general requirement for many valve pre-amps.
Old 27th October 2008, 08:47 AM   #812
Tolu is offline Tolu  Germany
Tolu's Avatar
My power amp needs a bit more "pedal on the metal". So, how can I add around 9-12 dB gain at the B1 or should I wait for B3?
Old 27th October 2008, 09:06 AM   #813
Floric is offline Floric  Europe
Without the addition of extra parts or a complete change of the topology, the b1 has no voltage gain, it is common drain. So you have to wait for the subsequent models or use the J-BOZ.
With best regards
Flo
Old 27th October 2008, 09:42 PM   #814
Default single sided B1 Buffer Layout
Offered here is an image of an alternate single-sided B1 Buffer layout. Input capacitors are axial lead, and pads for up to four inputs are included.
Old 27th October 2008, 10:44 PM   #815
Default single sided B1 pc board image
photo of single sided B1 pc board etched at home.
Old 27th October 2008, 11:25 PM   #816
Default B1 Buffer single sided pc board image
oops, picture was too large. here it is compressed. This board was etched at home using a solution of one part muriatic acid and two parts hydrogen peroxide (3%), and Techniks "press and peel blue" toner transfer sheets to form the etch resist mask.
Old 28th October 2008, 03:28 PM   #817
vonfilm is offline vonfilm  United States
Can anyone recommend a source for the 25K Ohm Linear Taper Mono Pots?
Also a good switch for 4 sources?
Looking for good quality on a budget.
Old 28th October 2008, 04:30 PM   #818
ebay-i bought 2 mono pots with 24 step discrete resistors for i believe 30 bucks for my b1 and they work great.mouser has a good "cheap" selector switch and parts connexion has a better one or try---you guessed it---ebay
Old 28th October 2008, 07:22 PM   #819
The one and only
Nelson Pass's Avatar
There is a B3 coming, and it has voltage gain.
Old 28th October 2008, 08:32 PM   #820
I've used a Grayhill rotary switch before for input selection and they seem nice. I'll have to double-check, but I think this is the model I used:
http://search.digikey.com/scripts/Dk...name=GH7102-ND
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright ©1999-2013 diyAudio
