B1 Buffer Preamp - Page 78 - diyAudio
Old 15th October 2008, 08:33 PM   #771
juma is offline juma  Germany
juma's Avatar
Default Re: Re: would this work?
Originally posted by Zen Mod
is this good ?
You need a small load resistor (RD in attached schematic ) on upper FET's drain so that cap can take that voltage swing down to lower FET's gate in order to modulate the CCS (Aleph's CCS does the similar thing)
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 15th October 2008, 08:38 PM   #772
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: Re: Re: would this work?
Originally posted by juma
You need a small load resistor (RD in attached schematic ) on upper FET's drain so that cap can take that voltage swing down to lower FET's gate.
nope ;
that cap is just for injecting noise from PS rail ;
at least seems logical to me - if ya can beat them , join them
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 15th October 2008, 09:32 PM   #773
juma's Avatar
Default Re: Re: Re: Re: would this work?
Aaahh, you want noisy CCS - to make buffer sound more "analog like" - yesss, what's music without noise, right ?
Old 15th October 2008, 09:36 PM   #774
maxlorenz's Avatar
I was thinking of the problem with the low psrr of the White jfet topology.
Better to have clean supply.
Old 15th October 2008, 09:44 PM   #775
Zen Mod's Avatar
Default Re: Re: Re: Re: Re: would this work?
yup - same as those headphones without cord ( workers in noisy
areas) ...... noise and anti-noise .....
anyway - I'm curious - Vaistiny Konza is - where ?
are you in tuzemstvo or inozemsvo ?
Old 16th October 2008, 06:48 AM   #776
sparky6 is offline sparky6  Canada
Default B1
Hi all,
I'm new to the forum and I'm not sure if this is the best thread to ask this question.
I've been using a Goldpoint SA4 level control between an Aragon D2A2 and an Aragon 8008BB. I've been wondering If I'd be better off with bit of gain instead. If so, would the B1 be the way to go? What would be the advantages over passive?
Thanks...
Old 16th October 2008, 07:32 AM   #777
stein2 is offline stein2  Serbia
stein2's Avatar
Default Re: B1
Originally posted by sparky6
Hi all,
Thanks...
B1 is a buffer stage, no gain in signal. If you think but not sure if you need gain, take a single pot, add some coax with terminals at both ends and try with passive volume only between your source (CD for example) and power amp. If you get enough output from source to fully drive the power amp, B1 should do. If you can go with the single pot all the way and feel that the amp lacks output power, then, some gain in the control/preamp unit would help. In that case, you might consider NS10 with a proper, modern shunt PSU... like some of us did
Threshold NS10 Lineamp PCB
and NS10 with Shiny PS
"Calculations? We don't need no stinkin calculations! We just make them really big!" - Papa
Old 16th October 2008, 08:52 AM   #778
brutepuppy's Avatar
Send a message via Yahoo to brutepuppy
OK guys,
here I am fat dumb and happy thinking I'm gonna build me a B1 to put into the system to replace the present POS preamp I have.
Now the hornets nest gets stirred a little and I hear (read) about Pumpkins and NS10's and ShinyPS's of which I know nothing about. I have no Pumpkin boards on order nor Shinnies nor do I know if I'll be able to obtain one should I need one. I feel like I got off the elevator on the fifth floor. I get the feeling I will need a "preamp" when all is said and done. Would that be a "pumpkin"?
Ray
Information is not knowledge
Knowledge is not wisdom
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
Music is the best !
Frank Zappa.
Old 16th October 2008, 08:59 AM   #779
juma's Avatar
Default Re: Re: Re: Re: Re: Re: would this work?
Ma jok, to je lokalna fora - Munze Konza (Zemun Zakon) ! Vaistinu Konza (Zakon) ! (tako se pozdravljaju i odpozdravljaju zemunci na satrovackom)
A dal'je tuzemstvo ili inozemstvo - ostaje da se vidi !
Anyway, I don't think that noise scheme will work here - it's quite different from Broskie's implementation in Aikido preamp. Furthermore, B1 doesn't need it - it has a very good intrinsic PSRR already. I know what would make you happy - nice, hot, glowing 6SN7 as WCF
Old 16th October 2008, 09:10 AM   #780
Originally posted by brutepuppy
OK guys,
Ray
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
Music is the best !
Frank Zappa.
help us to help you.
What do you want/need?
regards Andrew T.
Sent from my desktop computer using a keyboard
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright 1999-2017 diyAudio
