B1 Buffer Preamp
B1 Buffer Preamp
Old 28th September 2008, 02:47 PM   #681
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
A needy has a headache always yet.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 28th September 2008, 04:40 PM   #682
MRupp is offline MRupp  Germany
MRupp's Avatar
there is no need for complicating ...
I would hardly call two resistive dividers a complication unless you are ultra-orthodox; the question is really does the proposed method bring any advantage, such as cancelling out common mode signals, or does it not work. If you are going balanced you might as well try the best alternative.
Martin Rupp
Old 28th September 2008, 06:09 PM   #683
Gyuri's Avatar
Default van der Post
Touchdown Grey, I have to say it you have truth!
This is a better variant possibly here. The original book possibly is for you?
Gyuri
Old 28th September 2008, 08:16 PM   #684
systemerror909 is offline systemerror909  United States
Originally posted by Zen Mod
there is no need for complicating ;
one stereo B1 per channel , and that is balanced B1
if simplicity is goal , one can't make it much different
Is it really this simple? So each half of the balanced signal could go through this buffer, without say a negative rail voltage needed for the side the negative signal goes through?
If I just have to make two of these, that is easy.
Old 28th September 2008, 09:05 PM   #685
Tolu is offline Tolu  Germany
Tolu's Avatar
I would like to use the DS1802 digital pot in front of the B1 (or B3 ). NP uses the DS1802 in INT-150 and XP-10.
The main issues. More than 5V Vcc drives the pot into clipping. Proposal of Maxim: A wheatstone bridge!
The following stage should have a high impedance cause the DS1802 has 45kOhm impedance.
So, what solutions would be best to fit these two issues? How can I increase the input impedance of B1?
Perhaps NP could lift a little secret?
Old 28th September 2008, 10:33 PM   #686
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
Originally posted by Tolu
I........... How can I increase the input impedance of B1?
hardly
input imp. of B1 AFTER the pot is well near 1M , so you really don't need to increase it
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th September 2008, 01:56 AM   #687
wct is offline wct  United States
New subject maybe:
Hello All
Can someone tell me what a typical measured vgs is, when you do the test on LSK170's type "B" N FETs as outlined in Nelson Pass's article on matching?
These devices are headed for duty in the B1 buffer.
Ive measured about 20 of these devices now and I'm getting anywhere between .220V and .240V.
Does this sound correct?
I just want to make sure Im doing the test correctly by seeing if the results sound right.
I set up a little test setup based on Nelson Pass's device matching article and think I've followed it exactly as laid out in the article.
I used a 15 volt regulated supply, and a 2.2 K source resistor. The only way that I changed the procedure was to put a DC ammeter in series with the power supply.
I get a measured 6.67mA with just about every device.
So, is this in the ballpark? Thanks for the help.
Curt
Old 29th September 2008, 02:48 AM   #688
EUVL is offline EUVL  Europe
LSK170 is JFET and not MOSFET. For details, including matching you may read :
http://www.borbelyaudio.com/adobe/ae599bor.pdf
Excellent article.
Patrick
Old 29th September 2008, 07:12 AM   #689
MRupp's Avatar
I used a 15 volt regulated supply, and a 2.2 K source resistor.... I get a measured 6.67mA with just about every device.
Small wonder, a 2,2K source resistor will, at 6,67 mA, have 2200 * 0,00667 = 14,674 Volts across it, that allows the JFet barely to turn on and sets the limit for the current you can measure. First, a 100 Ohm resistor would be more appropriate for this JFET, at, say 10 Volts. Secondly, some basic reading on electronics would be in order, you should at least be able to calculate voltage/current/resistance.
Martin Rupp
Old 29th September 2008, 07:29 AM   #690
noelectrix is offline noelectrix  Europe
noelectrix's Avatar
hardly
so for an inpedance variing relay attenuator like Joshua (realatively low 2k to 3k typical) it would be most suitable to place it after B1? As long as the ground(s) of the different inputs is shared, it won´t produce earthquake Plops when "hot pluggin´" rca- connects, i guess.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
