B1 Buffer Preamp
B1 Buffer Preamp
Old 8th March 2018, 05:11 PM   #4421
Mixi is online now Mixi  Europe
Originally Posted by tborzic View Post
Hi, Would it be possible to increase R1 a bit in order to lower PSU voltage?
I will be using 20V PSU, so I was aiming towards recommended voltage, especially if BF862 would be in question.
If possible, is there a need for changing C1 also, since R1 and C1 are working/acting as noise filter?
Isn't the recommended voltage range 18-24V? So i guess 20V should be perfectly fine. On another forum people mentioned using it with power supply as low as 9V with good results.
Old 4th April 2018, 03:25 PM   #4422
fgroen is offline fgroen  Netherlands
fgroen's Avatar
I run my B1 off a symmetrical power supply with matched FETs, and did away with the input and output caps. Output offset is non-existent. Very pleased with the result.
I was wondering whether anyone has tried different JFETs, as the properties due to the buffer character may be a bit less critical compared to circuits with more than unity gain. I have procured some CPH3901's so will give them a try soon.
Old 5th April 2018, 09:42 AM   #4423
Stanislav is offline Stanislav  Australia
I have a B1 with 2sk369-GR.
It's been running for a good 3-4 years now. Magnificent!
Also ACA with 2sk369-BL (actually 5 channels). All good.
Soon will try it with the old 2N3819 (horror, horror!!!) cause I have hundreds of them.
Old 5th April 2018, 10:54 AM   #4424
fgroen's Avatar
The 2N3819 has an yfs between 3.0 and 6.5mS. Could that be the culprit?
Old 5th April 2018, 11:06 AM   #4425
It could be, but I guess if you parallel a few that can change.
Of course keep an eye on the Id and dissipation, maybe cascoding will help.
2n3819 is an exercise for the sake of it, as I said I have many of them and would prefer to use them one way or another than discard them.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
