B1 Buffer Preamp
B1 Buffer Preamp
Old 8th August 2008, 04:03 PM   #431
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
Originally posted by Tolu
Then I will hoard them and in 20 years I will sell them as NOS parts to ensure my retainment pay!
That's my plan, go find your own.
Old 10th August 2008, 10:46 AM   #432
BURNER is offline BURNER  Thailand
Hi Choky
Sorry for stealing your idea
I modified B1 power supply (BZLS style; positive side, IRFP240 instead of IRF610), replacing zener stack with 12 x small-green-LED stack.
The output is nicely stabilized at +19.4V
About the sound ...
Running LED-powered B1 with F5, it's huge improvement
* Mid seems to be warmer & sweeter
* High is more relaxed and silky
* Cleaner bass
Listen to a track 3 "High Life" of CD: Jazz at the Pawn Shop Vol.1 is a spooky experience as every instruments got better shape and focus !
Thanks for sharing your experiences
Old 10th August 2008, 11:05 AM   #433
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
Originally posted by BURNER
Hi Choky
Sorry for stealing your idea.............
yup ; I certainly invented that
when you have time - try B1 with split supply ( +/- 9V ) ;
you'll get rid of input cap , and even better supply rejection
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 10th August 2008, 12:50 PM   #434
Skorpio is offline Skorpio  Denmark
How critical is B1 layout corcerning stability?
Specially input and output wires....could the be close without problems?
Old 10th August 2008, 01:13 PM   #435
Zen Mod's Avatar
B1 Buffer Preamp
no more than any other low gain stage ;
so - keep those wires as much apart you can
Old 10th August 2008, 01:43 PM   #436
Tolu is offline Tolu  Germany
Tolu's Avatar
Default Re: Basically what I have done by now
Originally posted by salas
Found some spare time, and populated the perf-board. Done half the point to point also. I am putting together 1 positive & 1 negative regulated PSU, 1 output delay relay circuit and 2 channels of capacitor-less B1s. Hopefully in the next few days I will find time to finish it and test it little by little. Will report.
Next post includes the awfully sketched schematic.
Hi Salas
any listening experience yet?
Old 10th August 2008, 04:49 PM   #437
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
Had work to do and I left this little project behind. I will have to finish the point to point soldering and put it in a small plastic box along with a pot and connect it up so to see about offset behavior and square waves so to adjust resistors and PSU trimmers if needed. Then I will listen. If spare time is found, I will be ready to report everything in a couple of days.
Old 10th August 2008, 07:18 PM   #438
stigaard123 is offline stigaard123  Denmark
I saw with some interest, that a solution for a active crossover was possible with this simple and hopefully good sounding buffer. For a start I would like to make a active low pass crossover with 12db at 150 Hz.
I just added another B1 and placed R7 + R8 and C4 + C5 between the two B1's.
Is that all? Or are there more into it?
It is 6.8 db down at 150 Hz compared to the -20dB input, so it looks promising.
Old 10th August 2008, 07:37 PM   #439
I think your C4 should be connected to output instead of ground to get it right...
Old 10th August 2008, 07:47 PM   #440
Zen Mod's Avatar
B1 Buffer Preamp
Default deja vu ?
I saw with some interest..........
http://www.diyaudio.com/forums/showt...59#post1555159
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
