B1 Buffer Preamp
B1 Buffer Preamp
Old 11th March 2014, 03:43 PM   #3951
6L6 is offline 6L6  United States
6L6's Avatar
B1 Buffer Preamp
Use two closely matched pair, BUT put one pair in the "upper" position of each channel, (signal device) and the other pair in the "lower" (current source) position.
Old 11th March 2014, 03:53 PM   #3952
cwtim01 is offline cwtim01  Hong Kong
cwtim01's Avatar
Thanks 6L6 for the answer. Just to be sure I understand properly, do you mean it would be something like:
Left channel: signal - 15.90, ccs - 15.81
Right channel: signal - 15.91, ccs - 15.81
Old 11th March 2014, 03:58 PM   #3953
6L6's Avatar
B1 Buffer Preamp
Yes.
Old 11th March 2014, 04:00 PM   #3954
cwtim01's Avatar
Got it, thanks
Old 11th March 2014, 08:51 PM   #3955
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
Watch the dissipation as BF262 chance more like 2SK170V for IDSS.
Old 11th March 2014, 11:43 PM   #3956
cwtim01's Avatar
Thanks Salas, Andrew mentioned the same before. I'll probably stick a small piece of copper foil on them with thermal glue.
@18 degC room temperature and open space, running them @12V and idss for an hour, they aren't even warm. But it's probably very different in the summer, in a small case together with a shunt regulator.
Old 12th March 2014, 12:14 AM   #3957
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If they are not even warm then adding 30 degrees of summer heat is only going to make them warm.
Old 12th March 2014, 07:43 AM   #3958
spiri is offline spiri  Austria
spiri's Avatar
150mW on a BF862 with 1mm traces and Pads from the resistor nearby heated to 25C above ambient. Should be no problem even in a chassis.
If you have this power in a TO92 it runs hotter.
Kick it up a notch with www.akouo.at
Old 12th March 2014, 06:03 PM   #3959
cwtim01's Avatar
Thanks both
Old 16th March 2014, 08:52 PM   #3960
feds27 is offline feds27  United States
Default AULT / SL POWER / RESPIRONICS MEDICAL POWER SUPPLY
FYI, the Ault 18V 90W medical power supply model MW116 is now the SL Power MENB1090 also sold as Philips / Respironics 900-150.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
