B1 Buffer Preamp
B1 Buffer Preamp
Old 1st August 2008, 10:43 AM   #381
BURNER is offline BURNER  Thailand
Originally posted by Zen Mod
certainly ;
besides that - I wrote "...... even less" .
in any case - if you have problems with offset - then make small delay circuit which can switch off relay after 5-10 seconds ; relay contacts connected as short from output side to gnd
Thanks Choky
I'll go for 30+ sec
Old 1st August 2008, 11:15 AM   #382
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
Originally posted by BURNER
Thanks Choky
I'll go for 30+ sec
off course - in my previous post I meant on delay circ which will switch ON relay after some time ....... output of buffer is grounded via NC contacts .
plain delay circ with small darlington , few resistors and cap is good enough
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st August 2008, 02:36 PM   #383
A Sanchez is offline A Sanchez  United States
Default Some help please
A newbie here again.
I just want to copy the original B1 design without doing much work on the PSU, as I feel it is safer if I use something ready made.
So, I would be grateful if someone could tell me if in principle this 18V PSU would work:
http://www.effectpowersupplies.com/1...62&doy=1m8</a>
Many thanks
Antonio
[url]
Old 1st August 2008, 02:40 PM   #384
udailey is offline udailey  United States
Passive Aggressive
B1 Buffer Preamp
All you need is a cheapie $5 or less wallwart. Honestly.
You probably have one in your basement in that box o' cables and other junk you dont need anymore but since it was attached to something that cost a lot like a computer or router we seem to keep them in a big ol' box.
Just find one that is around 18V and you will be fine. It needs only 20ma so I doubt you can find an 18VDC wallwart that wont work.
Uriah
edit: in regards to your website
http://www.effectpowersupplies.com/1...supply-7-p.asp
will work fine, but its overpowered and expensive.
Old 1st August 2008, 02:53 PM   #385
Thanks Udailey,
I have not found 18V ones anywhere. What I found in shops are 9V and 12V ones.
Edit:
I think I will use two 9v ones and follow Zen Mod's kind suggestion: http://www.diyaudio.com/forums/showt...92#post1569192
I will keep looking.
Gosh, I hate the electrical part if DIY :
Antonio
Old 1st August 2008, 03:05 PM   #386
troystg is offline troystg  United States
troystg's Avatar
I have MANY 48VDC supplies available if they could be adapted to work. Note they are 120-240VAC compatible.
If anyone is interested they're free + shipping.
Here is a link someone ELSE has on ebay. I just have several of the same ones that are free and taking up space.
http://cgi.ebay.com/CISCO-AIRONET-Vo...QQcmdZViewItem
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 1st August 2008, 03:09 PM   #387
Thanks Troy, but I read somewhere that the B1 requires between 18VDC and 24VDC.
Old 1st August 2008, 06:55 PM   #388
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
I have run those buffers as high as 40V.
Old 1st August 2008, 07:03 PM   #389
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
No problem indeed.
Old 2nd August 2008, 06:33 AM   #390
Salas's Avatar
B1 Buffer Preamp
Guys, I have looked in an old parts box and I have 10x 2N5459 and 6x 2SK170BL. The 5459s bunch around 5-6mA Idss. And I measured 2 matches. 2x5mA & 2X5.2mA. The 170s are 6.9, 8.7, 7.7, 6.8, 8.2, 7.35 mA.
What do you think? Use the 5459 pairs for an attempt on a hopefully capacitorless B1, or prefer the 6.9+6.8, 7.7+7.35 mA 2SK170s? The 5459s have a dB or so more noise on paper, but for a line buffer isn't a big deal. ----The main question is, do 2SK170s sound detectably better than mundane N-JFETs, when noise is not an issue?---- Does anybody know? Nelson?
I can make it on perfboard, complete with 317-337 symmetric supply and lose at least the input cap. I will also use an output delay relay circuit if the equilibrium offset is very low so to lose Cout too, and avoid turn on thumps. The 5459s look like yummy matched pairs for that goal, and I can save the 2SKs for some single ended 2 stage zero feedback MM preamp where I can match their gain by Rs. I can not find more 2SKs right now at the shops.
Basically it will be nice to have a tiny buffer box that sounds decent and is mobile. Interesting to see how it performs against my preamp too (in attachment).
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
