B1 Buffer Preamp
B1 Buffer Preamp
Old 4th August 2013, 01:20 AM   #3821
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
B1 Buffer Preamp
Post 53 of this thread juma has a great simple pre that I have been using for some time. I have it at one input of my dcb1 to help my iPad out.
Preamp ideas for F5
http://www.evancotler.com
Old 4th August 2013, 02:25 PM   #3822
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
A computer sound card is not exactly TOP-END Hi-Fi so if you do need a bit of amplification a reasonable op-amp would do the trick. (The computer's sound card will be using them anyway).
Old 5th August 2013, 01:05 PM   #3823
WalterW is online now WalterW  Netherlands
B1 Buffer Preamp
Thanks everybody! I know my soundcard isn't the best. Next project will be to build a reasonable USB-DAC. Maybe I can select a DAC with a higher output voltage, and not needing a preamp anyway.
Now still busy finishing my loudspeakers
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 9th August 2013, 12:15 PM   #3824
Rixsta is offline Rixsta  United Kingdom
B1 Buffer Preamp
Originally Posted by AndrewT View Post
This seems broken.
Most properly built B1 have zero Output offset. The DC blocking cap and the leakage to signal ground resistor ensure the output offset is zero.
0.01Vdc = 10mVdc is wrong.
0.34Vdc = 340mVdc is broken.
So Im thinking that the B1 I got was from china, possibly dodgy fake transistors causing the problems. SO before i give up on B1 am going to order some 2SK170 from germany, no wonder the sound didn't sound good before!
Will check the resistors before ordering the new Fets.
www.rikibuckingham.com...
Old 10th August 2013, 09:25 AM   #3825
R.I.P.
The B1 is available from Pass.
regards Andrew T.
Old 13th August 2013, 09:17 PM   #3826
WithTarragon is offline WithTarragon  United States
Originally Posted by 6L6 View Post
There is another solution - if you don't want to have an active preamp to get the signal to full output, make the amplifier more sensitive so your 1.5V can drive the amp to full output.
It's very simple - make the feedback resistors (R7, R8, R9, R10) 220ohm. This will increase the amps gain at the expense of a little feedback and you can now clip it with a CD player or computer.
Regarding this suggestion on increasing the amp's gain, by doubling the values for the feedback resistors.
I assume the only penalties are an increase in harmonic distortion (which is aleady quite low) and an increase in output impedance. Has any one actually done this and measured it. Or is there a calculation that will give me a ballpark estimate.
Old 13th August 2013, 11:01 PM   #3827
6L6 is offline 6L6  United States
6L6's Avatar
B1 Buffer Preamp
I did it with 150ohm and it worked wonderfully. Quite a few others have used 220 ohm and reported back nothing but good.
Old 21st August 2013, 10:25 PM   #3828
Earthloop is offline Earthloop  United Kingdom
Default B1 Surpassed
Hi Folks,
This maybe the wrong thread for this post, so apologies in advance, but further to my previous post, 23/06/13, about the B1... After many hours of critical listening, I have the concluded that the B1 just does not sound right with my A40 monoblocks. So I built the JLLH buffer with ripple eater PSU's and the sound is mind blowing. This thing just ROCKS!!
Old 21st August 2013, 11:00 PM   #3829
6L6's Avatar
B1 Buffer Preamp
Interesting ! Do you have any links or information on it and the PSU ?
Old 22nd August 2013, 12:30 AM   #3830
flg is offline flg  United States
flg's Avatar
Originally Posted by Earthloop View Post
Hi Folks,,,
... So I built the JLLH buffer...
Is that a small typo there?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
