B1 Buffer Preamp
B1 Buffer Preamp
Old 28th June 2013, 01:52 PM   #3781
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
That'll be the same one that I found.
Old 28th June 2013, 02:40 PM   #3782
sangeet2 is offline sangeet2  Germany
In yours?
Old 28th June 2013, 03:19 PM   #3783
But its funny anyeay, cause the guy from the other forum shows a pic where this
caps are also installed…
http://diyaudioprojects.com/Forum/do...4027&mode=view
But he didnt put in a pot...
Old 29th June 2013, 03:40 PM   #3784
As I said before, try reverse engineering the board. I suspect that there is something wrong somewhere. It's a simple enough circuit to check. The problem that I had was that there an incorrect connection to the 0V top plane.
Old 26th July 2013, 07:53 AM   #3785
Rixsta is offline Rixsta  United Kingdom
B1 Buffer Preamp
Hi, I have a 18 V, 5.0 W Zener Diode Voltage Regulator
I presume with just a simple circuit and this Diode i can have a nice steady 18v PSU.
Do i just attach the diode over the Rectifier outputs or ?
Ill search for some diagrams
www.rikibuckingham.com...
Old 26th July 2013, 12:20 PM   #3786
udailey is offline udailey  United States
Passive Aggressive
B1 Buffer Preamp
It needs a series resistor to limit current or it'll burn instantly.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 2nd August 2013, 12:57 AM   #3787
B1 Buffer Preamp
aha thanks, well used an online calculator had a 400ohm resistor with the 18v Zener and worked for a while, power slowly rising on turn on up to 17v for the B1 then after a while i guess the Zeener just died as the voltage slowly dropped then nothing !
Hmmm back to the drawing board how to achieve 18v from 26vDC
I think i just fried a Zeener
Perhaps Ill just change the Caps in the B1 for higher voltage and run it from the 26v DC, If 26 is not too high for B1
Old 2nd August 2013, 03:24 AM   #3788
6L6 is offline 6L6  United States
6L6's Avatar
B1 Buffer Preamp
LM7818 LM7818 PDF Datasheet 3-Terminal 1A Positive Voltage Regulator
LM317 http://www.google.com/url?sa=t&rct=j...,d.aWM&cad=rja
Old 2nd August 2013, 05:02 AM   #3789
400mW Zener at 18V should be capable of withstanding 22mA.
26 - 18 / 400 = 25mA, so 400 Ohms was slightly too low.
1K would be OK.
B1 will run on 26V anyway !!!!
Old 2nd August 2013, 10:41 AM   #3790
B1 Buffer Preamp
Hey, Thankyou
Decisions Decisions upgrading the power caps to run the B1 from 26v seems easiest solution ill Probably go with that. yes Id had a 470ohm resistor.
Does anyone know of a good soft start circuit that wont take weeks to arrive in the Uk lol there's a turn on thump on the B1 which id prefer to get rid of!
im thinking Just get a soft start for the whole amp
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
