B1 Buffer Preamp
B1 Buffer Preamp
Old 28th June 2013, 12:26 PM   #3771
sangeet2 is offline sangeet2  Germany
My test setup is this:
Macbook-Apogee One-Rotel HiFi amp.
I also tried it with a CD player as source...
Old 28th June 2013, 12:27 PM   #3772
Originally Posted by KatieandDad View Post
What is the output impedance of your source ?
Apogee One is 30 Ohm
Old 28th June 2013, 12:30 PM   #3773
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
If everything is OK then it might be down to the rest of the set-up. The B1 is pretty transparent so wont affect the frequency response of the rest of the set-up. Try taking the B1 out of the system by simply connecting the wiper of the volume pot to the power amplifier.
Old 28th June 2013, 12:32 PM   #3774
Hmm, if I dont put the B1 inbetween everything is good. In the Rotel I am using the Input for tuner...
Old 28th June 2013, 12:35 PM   #3775
In my B1 I used DIY boards derived from the PCB layouts on the Pass DIY site. Even then I found discrepancies. I would check your boards very carefully by reverse engineering the schematics. Also check VERY carefully for hairline whiskers of copper or solder.
Old 28th June 2013, 12:35 PM   #3776
Ok will do this
Old 28th June 2013, 12:36 PM   #3777
Did this already but will do it again,
Old 28th June 2013, 12:44 PM   #3778
Without the B1 pot is working fine
Old 28th June 2013, 01:06 PM   #3779
Reverse engineer the board. I suspect that there is an error somewhere.
Old 28th June 2013, 01:16 PM   #3780
Ok, it looks like I found a msitake on this PCB from the other forum. There is one cap with 0,1uF called C4. This one is not in the original B1
If I take this off my pot behaves normal
Thanks alot for your input!
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
