B1 Buffer Preamp - Page 377 - diyAudio
Old 28th June 2013, 11:44 AM   #3761
Any more suggestions what I can do about would be great
Old 28th June 2013, 12:06 PM   #3762
KatieandDad's Avatar
Silly question but have you got the volume pot connected correctly.
Old 28th June 2013, 12:07 PM   #3763
Thanks for your input
Yes pot is correct connected. If I dont put the pot but only the 1k resistor I also have the high frequencies damped
Old 28th June 2013, 12:09 PM   #3764
It does look as though you have managed to make a variable filter at the input to the B1. Try increasing the size of the input caps.
Old 28th June 2013, 12:11 PM   #3765
Hahah, you´re right.
Old 28th June 2013, 12:15 PM   #3766
What was wrong ??
Old 28th June 2013, 12:17 PM   #3767
I still dont know what is wrong. My input cap is a Solen 1uf. I can put in a higher cap and report back
Old 28th June 2013, 12:21 PM   #3768
1uF should be fine. Are you sure its 1uF and not a fake - incorrectly labelled. If the cap is good and the pot is correctly wired you might have an impedance mismatch with your source. IE the frequency attenuation might be being caused by the volume control interacting with the output cap of your source.
Old 28th June 2013, 12:23 PM   #3769
The Solen is from a very good seller Tubetown. Also I measured it before...
Old 28th June 2013, 12:24 PM   #3770
What is the output impedance of your source ?
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright ©1999-2017 diyAudio
