B1 Buffer Preamp
B1 Buffer Preamp
Old 24th June 2013, 11:36 AM   #3751
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I seem to recall that the Obligattos were only about £9 each.
Old 24th June 2013, 12:45 PM   #3752
Originally Posted by voxxonline View Post
Ok. Regarding Obbligatos. I like them (thanx to KatieandDad) but I think very worthwhile alternative is my MBGO 2 caps NOS from Russia.
I might reverse back to them after all...
You can use anything you like as long as you can make it fit. Although the Obligattos are HUGE they did fit.
Old 24th June 2013, 01:00 PM   #3753
udailey is offline udailey  United States
Passive Aggressive
B1 Buffer Preamp
Great bang for buck cap.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 27th June 2013, 04:00 PM   #3754
sangeet2 is offline sangeet2  Germany
Dont´t know where I should post in this thread with my problem, so I try here.
As soon as I turn the volume down in my B1, also the high frequencies getting damped.
I have to say that in the first place I installed the transsitors wrong with 180 degree. Now I installed them correct but the problem remains
Old 27th June 2013, 04:28 PM   #3755
Are you using Pass B1 or one of the derivatives ?
Old 27th June 2013, 05:02 PM   #3756
I am using a PCB which I found here
DIY Audio Projects Forum • Pass B1 buffer clone (be1) with layout - A weekend project.
Old 27th June 2013, 08:19 PM   #3757
Itsmee is offline Itsmee  England
Itsmee's Avatar
What value is the pot? Is it before or after the B1.
Old 27th June 2013, 08:48 PM   #3758
I tried different pots from 10k to 50k. Its (of course) before
Old 27th June 2013, 09:30 PM   #3759
Itsmee's Avatar
Originally Posted by sangeet2 View Post
I installed the transistors wrong with 180 degree. Now I installed them correct but the problem remains
JFETs are symmetrical in construction so should have survived, but thats no guarantee.
Do you have access to an oscilloscope and signal generator to see if you have a bandwidth problem when the signal is attenuated.
Old 27th June 2013, 11:00 PM   #3760
Hmmm, I have my ears
Also I do have Pink Noise generator from Logic as software and some software scope
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
