B1 Buffer Preamp - Page 369 - diyAudio
Old 7th April 2013, 12:57 PM   #3681
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Cheers much appreciated! shall make my decision on which to go with today.
the other thing is line-out i would like to add one, would there be a proper way to do that with the B1 ?
my friend wants to feed a line out to a different amp so that he can chose which amp or even both the music from say CD player is played on.
Thanks Mark for the radioshack recommendation ,looks good yes i think ill be able to suss out how to wire the Potentiometer with a bit of time.
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 7th April 2013, 01:45 PM   #3682
Having real trouble finding Dual Gang 25k Potentiometer at 0.25"
This is the closest Iv'e found and its 47k not even ebay has them in this size
27ESB473MMF50NF - TE CONNECTIVITY / CITEC - POTENTIOMETER, D/GANG LOG 47K | Farnell United Kingdom
Is there a way i can modify to work with a lower or higher than 25k pot ? i think if i was clever i could calculate series/parallel resistor to add lol
The selector switch im happy with and think this cost is worth it as i think its well built!
http://uk.farnell.com/grayhill/71bd3...15v/dp/1625819
Old 7th April 2013, 03:14 PM   #3683
Marra is offline Marra  United Kingdom
It makes Farnell expensive with the 15.95 charge for US shipping.
Old 7th April 2013, 05:45 PM   #3684
already have a 100 order together so
Old 8th April 2013, 09:58 AM   #3685
AndrewT is online now AndrewT  Scotland
Is there a 20k or 22k pot that is within your budget?
At a push you could use 10k, if your sources can drive that Zin?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th April 2013, 10:01 AM   #3686
Rixsta, the B1 will work with higher K pots. it.s just that 25K is the recommended one. Yes I found they are a little difficult to get and have settled on 2 mono 25K 24 Step Ladder Type Mono Volume Control Attenuator (item No310603383314) from Ebay @ US$26. They also do a stereo pot but I still like to have some balance control over my system.
tabarddn
Old 26th April 2013, 04:49 PM   #3687
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
found I had a nice trafo
and also have some macthed LDR
so I hope its ok to try and build Nelson's B1 buffered LDR volume control
Old 27th April 2013, 11:02 PM   #3688
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
What kind of strain relief is this on the power cord of Nelson's B1?
Old 28th April 2013, 02:50 PM   #3689
Something like this.Should be available from Mouser or Digikey.
12237 - BULGIN - STRAIN RELIEF, BUCCANEER | Farnell United Kingdom
Old 11th May 2013, 10:44 PM   #3690
mach1 is offline mach1  Australia
Banned
. Having real trouble finding Dual Gang 25k Potentiometer at 0.25"
Tocos Cosmos 20k - excellent pot, suits the B1 perfectly.
potentiometers, switches and attenuators homepage
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright 1999-2017 diyAudio
