B1 Buffer Preamp - Page 360 - diyAudio
Old 8th October 2012, 05:09 AM   #3591
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
P.S. If you can't find very good matches because just six, use the lesser IDSS one in a channel pair as the one with g,s pins going together in same node.
Old 8th October 2012, 05:14 AM   #3592
tessier is offline tessier  Canada
Hi
How much close we need to match jfet to put two in parallel in the B1 circuit ?
Thanx
Paul
Old 8th October 2012, 05:49 AM   #3593
Salas's Avatar
Don't do it, its not a proper B1.
P.S. IDSS is only indicative of Vgs(off), Yfs, those are not exact in each die for even same ID. And then you got two different housings trying to follow in each position each other thermally and double the Ciss making it slower, leads and traces... no cigar, no real B1, you lose much more than in a GR B1.
Old 8th October 2012, 06:13 AM   #3594
Hi
Ok, no paralleling.
But anybody know how much more thd wen using 2SK170 with only 5 ma IDSS in the B1 ?
Thanx
Paul
Old 8th October 2012, 06:17 AM   #3595
Salas's Avatar
Depends on signal level a lot too. Someone has got to make or simulate GR and BL B1 then FFT from min to max level so to speak in numbers.
Old 8th October 2012, 06:29 AM   #3596
Hi
I use Ltspice but the 2SK170 model do have a IDSS of 10ma
.model J2sk170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Betatce=-.5 Lambda=1.923m Vto=-.5024 Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 Fc=.5 Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p N=1 Xti=3 Alpha=10u Vk=100 Kf=111.3E-18 Af=1)
How can we change this model IDSS to 5 ma ?
Thanx
Paul
Old 8th October 2012, 06:37 AM   #3597
Salas's Avatar
Lower Beta to 30m then Vto, until you will see 5mA for a k170 g,s shorted to gnd off a 9VDC source.
Old 8th October 2012, 06:53 AM   #3598
Hi
Here is the new model for the 2SK170-GR, it have a IDSS of 5.04 ma. with a
9 volt dc source.
.model J2sk170gr NJF(Beta=30m Rs=4.151 Rd=4.151 Betatce=-.5 Lambda=1.923m Vto=-.4274 Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 Fc=.5 Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p N=1 Xti=3 Alpha=10u Vk=100 Kf=111.3E-18 Af=1)
Thanx
Paul
Old 8th October 2012, 06:51 PM   #3599
Hi
I've done Ltspice simulation of the B1 using those two model to compare.
The BL type of 2sk170:
.MODEL 2sk170 NJF (VTO=-5.211e-001 BETA=3.683e-002 LAMBDA=4.829e-003 IS=1.000e-009, RD=0.000e+000 RS=0.000e+000 CGS=5.647e-011 CGD=2.562e-011 PB=4.860e+000 FC=0.5)
The BR type of 2sk170:
.MODEL 2sk170b NJF (VTO=-4.911e-001 BETA=1.983e-002 LAMBDA=4.829e-003 IS=1.000e-009, RD=0.000e+000 RS=0.000e+000 CGS=5.647e-011 CGD=2.562e-011 PB=4.860e+000 FC=0.5)
I simulated with a 1 volt 1 khz signal at the B1 circuit input.
Adding a low pass filter capacitor at the input did cut a lot the thd of the BR type of 2sk170.
Thanx
Paul
Old 8th October 2012, 07:07 PM   #3600
Salas's Avatar
With 24V supply its probably able to go near that as Vpp out max. What does with 2VRMS which is a typical digital source? Some go 3VRMS, what ever. Can you post the .asc so I get to see the details?
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright 1999-2017 diyAudio
