B1 Buffer Preamp - Page 356 - diyAudio
Old 27th June 2012, 09:21 PM   #3551
juanitox's Avatar
sounds intersting , is there a schm or a thead about it here ?
French is not a crime.
Old 27th June 2012, 09:24 PM   #3552
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nope ............. and many
visit us these dayz in da pub and remind me to draw it
I'm having PITA lately drawing schm , because my trusty scanner is refusing to work under 7-th Schweindoze
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th June 2012, 09:38 PM   #3553
juanitox's Avatar
i have some lundhal cascode CCS here , best is to use it in place of the 15V reg on the upper jfet or down in place of the -15 reg ??
gime some works for tomorrow ,,,
Old 27th June 2012, 10:14 PM   #3554
Zen Mod's Avatar
Originally Posted by juanitox View Post
...... lundhal cascode CCS ....
Old 27th June 2012, 10:17 PM   #3555
juanitox's Avatar
some of these CCS Click the image to open in full size.
( DN2540N5 and IXYS IXTP01N100D depletion mode MOSFET)
is it good for the upper JFEt after or in place of the Regulator?
Old 27th June 2012, 10:30 PM   #3556
Zen Mod's Avatar
naah
that's hi-voltage thingie ...... no need for that
whatever - you need somewhat elevated B+ (say 20-25V) ,BC546 as cascode above upper jfer placed at 12-15V ;
you can leave lower Jfet as is , or replace it with Widlar CCS , with multipot for setting
I told ya - I'm lazy for puter drawing , and I need new scanner
whatever - main obstacle is that I have some things to finish tonight and tomorrow ..... going to see my Yoda (Manu) early morning Friday
Old 28th June 2012, 06:46 PM   #3557
juanitox's Avatar
take your time l'ami ! today i just put a 40ohm R before the 15000uf Cap to make a RC filter no change , then swapp the output series Kiwame 240ohm Resistor what makes a big change , better bass , dynamics , everything pops.. ( no oscillation with a 20K / 40K square wave)
i keep the 240 kiwame input ( for the moment!)
Old 28th June 2012, 07:02 PM   #3558
Zen Mod's Avatar
you can toss that output resistor
Pa put it there for sissies
Old 3rd July 2012, 06:33 PM   #3559
KatieandDad's Avatar
Default Fitting Obligattos to B1
I have been asked how I fitted the Obligatto 10uFs into the B1.
I used a clone of the full Pass B1 build, which uses a huge PCB when compared to the Salas B1 and DCB1 boards.
The PCB is big enough to accomodate the huge Obligattos with the leads looped under the board and connected underneath the board on the copper track side. I also fitted two cap clips to hold the big caps in place.
If you want to do this mod. to the smaller Salas boards you will need to short out the output caps on-board and fit the SODA CANS away from the board.
Old 3rd July 2012, 07:48 PM   #3560
OlavHaal's Avatar
Default B1 with 240 ohm???
Hi Juanitox!!
This turn on the B1 seems interresting... but after my schematic and the one I see on Passdiy.com there are no 240 ohm resistor neither on the output or on the input??
I wonder if you mean the R204 that is 1Kohm - that is the one you are changing with the Kiwave-resistor?
Now I have moved my BIG Obligato10uf to the SIT so there are no output cap and maybe a new Kiwave on the input AND output of the B1 can keep the sound even more touchable?
Is the sound you get worth a try Juanitox???
Best from a guy out in the open NorthSea
Olav
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
Copyright 1999-2017 diyAudio
