B1 Buffer Preamp
B1 Buffer Preamp
Old 16th May 2012, 03:11 PM   #3521
sachu888 is offline sachu888  India
sachu888's Avatar
Originally Posted by tinitus View Post
lets us know how it goes
Sure,I will update here.
Sachin
Old 19th May 2012, 06:20 AM   #3522
gadut is offline gadut  Indonesia
gadut's Avatar
My first learning on pcb layout, previously I use schematic menu then convert to pcb. It was so frustating for newbie like me. Then I started to design from pcb menu by placing each component 1by1. I never thought that designing pcb will be so much fun by using 3D rendering from diptrace
Need your advise on my layout
Old 19th May 2012, 06:33 AM   #3523
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
B1 Buffer Preamp
looks great
but might be a bit tedious getting to the jfets, if you should need to do repair or something
appears to me like the jfets would fit nicely into the space at the end of the caps
and according to your copper lines, it would make a natural and shorter connection as well
Old 19th May 2012, 11:04 AM   #3524
Giobax is offline Giobax  Italy
Here is my interpretation of B1. Thanks to Nelson Pass and Salas for sharing their great projects.
Giovanni
Old 19th May 2012, 11:09 AM   #3525
B1 Buffer Preamp
ah, a real beauty
Old 19th May 2012, 12:00 PM   #3526
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Nice work. I like the use of the extension rod on the volume pot.
What is the purpose of the alluminium u frame between the PSU and the B1 ? It certainly has no screening properties.
GADUT, I simply downloaded the Gerber files from the PassDIY site and used a FREE Gerber viewer to convert them into .jpg images.
Then it was a simple matter of producing them.
I did cheat though. I only etched the bottom copper layer. The upper layer remained intact. After clearance drilling the necessary holes I made the necessary upper tracks with insulated wire - EASY.
Old 19th May 2012, 12:00 PM   #3527
rookakoma is offline rookakoma  Hungary
rookakoma's Avatar
This is a point to point wiring dc coupled B1 buffer with a stepped attenuator volume switch.
Old 19th May 2012, 12:12 PM   #3528
Hi. Are you referring to the material or to the form of the frame?
Giovanni
Old 19th May 2012, 12:15 PM   #3529
I was just wondering why you put a huge alluminium U Frame in the middle of the pre-amplifier.
Other than giving it strength it doesn't do anything.
It does look good though.
Old 19th May 2012, 12:34 PM   #3530
Default The original B1 PCB
These are converted from the Original Gerber files which are FREE to download.
many guys have modified them to include different caps. My big Obligattos simply connect though holes in the board to the original pads.
I also cut the 0V trace on the bottom of the board (the thick one between the top and the bottom) as this is already made by the 0V ground plane on the other side of the board.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
