#3391 | |
#3392 |
diyAudio Chief Moderator
Got BSS135 Siemens TO-92 DMOS too but it has 110-150pF Ciss for 10 to 40mS only. Better a JFET. When BS170 has 30pF and 300mS. If there is a dynamic gm and low Ciss DMOS all to the better.
#3393 |
Ha !
(even prettier is shaving the body to the bare minimum thickness, and/or encase it into a larger high thermal epoxy body)
Looks like Sponge Bob has killed another thread. |
#3394 |
Well, all I'm saying is that this circuit treats the upper transistor as a depletion mode MOSFET instead of a jfet. It seems to be made for those kinds of devices.
#3395 |
Patrick (EUVL) developed a rather good higher current buffer running about 250mA called the"DAO Buffer (Taylored) with the Lu1014 jFets plus cascode - driver for the AKG k-701 headphones - extremely good, simple device especially with the Shunt Regs, but don't know if it's actually a B1 variant ....
... jh |
#3396 |
All,
I apologize if these measurements exist in this long thread. I am (finally) getting around to completing my B-1 with Pass Boards. I didn't burn anything up on initial power up (at least no smoke)... but I'm not getting anything from the output... save for some very faint audio. (yes, it is connected to my power amp) Can anyone tell me where I might find voltage measurements at some points in the circuit so that I may trouble shoot and identify where I might have made a mistake? It seems silly that it's not working given the simplicity of the circuit and the great board. Alas... obviously I've done something incorrectly. I have a 24 volt supply. I know the current draw of the circuit is approximately 20 mA. The voltage drop across R1 doesn't tell me anything, i.e. no stable measurement with my DVM. The power indicator LED lights up just fine. Thanks for the help. Ryan
Lighten up while you still can ... |
#3397 |
RKH - well lit, detailed photos please!
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#3398 |
Check the voltage on the drains of the JFET Q100, Q200. They should be around +10V each, and each source should be at or near ground. Q201 and Q101 should each be sourcing about 10mA. Also are both channels the same? That could be a clue.
#3399 |
Just finished a fully differential version of the B1 Buffer. Details about design, execution, and how it sounds are posted at
Audio Equipment It sounds wonderful. Much improved over a passive attenuator we were using before this. |
#3400 | |
| buffer/preamp? | TheDriver41 | Chip Amps | 2 | 3rd October 2004 08:40 AM |
| Page generated in 0.12249 seconds (72.92% PHP - 27.08% MySQL) with 11 queries |
