#3121 |
15,000 seems a little overkill. Maybe inrush current is a little high. But don't those three pin regulators have overcurrent protection? I'd think a discrete shunt regulator circuit would work better.
#3122 |
isn't the B1 supposed to be used with a 'standard' external regulated supply
I even think a particular one is suggested in manual with this low 'power' draw, I guess its basicly like running on batteries unless...maybe shut down bleeders may be working against this funny....but I think I have read that high capacity caps will be replacing much more battery functions in the future |
#3123 |
actually, with a 100.000uf cap I reckon a B1 would work all day, dissconnected from power source
mind you, I'm not suggesting to do that only saying it might be possible |
#3124 |
The stock value of 15,000uf is there so the original PCB can be used with an unregulated supply, such as a wall-wart.
If you have a regulator, a smaller value cap could be appropriate. |
#3125 | |
Mr. Pass says anywhere between 1000uF to 15,000uF so there is a good reason for the wide range. justed want to know why. |
#3126 |
I once tried one LM3886 with a total of 200.000uF at +-35v. It stayed playing for half a minute at moderate volume with the power cord disconnected.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#3127 |
I thought that it was large inrush current on power-up that could kill the regs ?
If you deal with that, and stays well inside the current draw limit, what else problems could there be |
#3128 | ||
![]() (If it helps for me to be more specific, I have a choice of the following caps: 4,700uf, 1,000uf, 330uf, 100uf, 10uf, or 1uf.) Which one? ![]() Quote:
I have little interest in undertaking construction of another regulator circuit, (especially one that approaches the B1 in complexity). I want to be done with it so I can listen to music soon! ![]() Thanks all! -Chas |
#3129 |
Clm,
the B1 has only 2 active devices in each channel. It does not need a regulated supply. Just follow Pass build instructions. |
#3130 |
100/200uF plus 0.1uF film should be OK.
| buffer/preamp? | TheDriver41 | Chip Amps | 2 | 3rd October 2004 08:40 AM |
