B1 Buffer Preamp - Page 311 - diyAudio
Old 15th August 2011, 07:12 PM   #3101
wijgers is offline wijgers  Netherlands
Question B1 PCB
Are there by any chance still B1 preamp PCB's available?
I know they can be made p2p, but the final amp I want to make on an PCB
Nils
Old 15th August 2011, 07:16 PM   #3102
Marra is offline Marra  United Kingdom
Nils
Straight to the man.
DIY Order Form
Old 17th August 2011, 07:17 PM   #3103
Bengali is offline Bengali  United States
when using a volt. regulator for 24V output, what should the cap value be on the output of the regulator and on the B1 pcb?
with the v.reg, you really don't need 30,000uF or they should still be used?
Old 19th August 2011, 06:03 PM   #3104
TazSC is offline TazSC  United States
Default polarity
Does the B1 invert polarity?
Old 20th August 2011, 12:58 PM   #3105
Itsmee is offline Itsmee  England
Itsmee's Avatar
No.
Old 21st August 2011, 12:43 PM   #3106
richluvsound's Avatar
Default Suggested Dale
Gents ,
I'm trying to find the RN-55D .25 watt resistors NP suggested in the PDF .
I found .5 at digikey ,but .25 ..
any suggestions please ?
thank , Rich
Old 21st August 2011, 01:03 PM   #3107
udailey is offline udailey  United States
Mouser has them, so does Allied. Or, use .5w. BTW, digikey is great, but most expensive.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st August 2011, 01:07 PM   #3108
Itsmee's Avatar
Originally Posted by richluvsound View Post
Gents ,
thank , Rich
Try Mouser, Vishay CCF55 series
Vishay Mouser Electronics - Electronic Component Distributor Metal Film Resistors
Old 21st August 2011, 01:18 PM   #3109
thank you
Old 26th August 2011, 09:28 AM   #3110
Itsmee's Avatar
What is the difference between the P-MEZB1-1V10 and P-MEZB1-1V10e boards?
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright 1999-2017 diyAudio
