Old 11th June 2011, 08:04 PM   #2981
Itsmee is offline Itsmee  England
Itsmee's Avatar
That would be perfect
Old 11th June 2011, 08:46 PM   #2982
tinitus is online now tinitus  Europe
OK
many thanks
need to buy a few parts now
I have small 2x22Vac C'core trafos, so I will use regulated supply
and maybe a bunch of small caps after that
Old 12th June 2011, 02:38 AM   #2983
udailey is offline udailey  United States
Passive Aggressive
Tinitus
I havent built this but the 150k resistors might make it hard to use. I suggest try trimmers there first, then replace with resistors. Good luck. Looks like a fun and educational project.
PS when you first fire it up please have those trimmers at full resistance, then with a DMM on the resistors side of the LDR.. turn the trimmer down til you get desired resistance of 40R on shunt at min volume and no less than 40R on series at max volume. Then you know you are safe and not burning the LED in the LDR.
If you can adjust overall Rtot of your LDR attenuator I suggest trying to go as low as you can and still have whole circuit stable. I enjoy 6k very much. Super detail and transparency down there.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 12th June 2011, 03:19 AM   #2984
hey, Uriah, my LDR expert man
are you sure it works like the usual LDR curcuit
somehow it looks different to me
att 'voltage' pot looks to me more like a balance pot
would the load voltage to LED's not be more like the difference between positive and negative
or something like that
Old 12th June 2011, 02:47 PM   #2985
found an easy to build regulator
only to find the regulators obsolete
well, maybe lacking precision
and not good at all
and another problem
my 2x22V trafos seems a bit much
Old 12th June 2011, 02:55 PM   #2986
6L6 is offline 6L6  United States
6L6's Avatar
Why not parallel the output of your transformer, and use a standard LM317- derived regulator? You only need to get the output voltage down to 22-23 volts.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 12th June 2011, 06:29 PM   #2987
ah, yes, I was thinking maybe adjustable would be better with the higher voltage trafo
using double secondary(not CT), and double bridge, I can stack two LM317, side by side, to form the +/- supply
this would be ok, right ?
Old 12th June 2011, 08:53 PM   #2988
ah, ok
Old 12th June 2011, 09:40 PM   #2989
when you use a dual secondary transformer, all the options shown in posts 2985, 2987, 2988 work.
The 78xx series of regulators are still available and do work. An ordinary 317 without the regulation improvements added performs about as well as a 78xx reg.
Old 12th June 2011, 09:42 PM   #2990
6L6's Avatar
If you use a full-wave bridge your AC will be smoother and the regulators will be under an easier load. Don't forget to use big heatsinks if you are planning to throw away a lot of volts.
Pass F4
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright ©1999-2013 diyAudio
