B1 Buffer Preamp
B1 Buffer Preamp
Old 30th May 2011, 04:34 PM   #2961
lolo is offline lolo  France
lolo's Avatar
Hi Jim,
This is the one:
Préamplification - Contrôleur de volume stéréo à commutation de résistances
Cheers!
Old 3rd June 2011, 08:29 AM   #2962
tsip is offline tsip  Greece
If i understand correct what you want to do, then connect the relay volume pot to the input selector as you would normally do and then connect the input selector to one of the B1 input as in the picture a couple of posts before. You will then have to put jumpers at the B1 board at the place where the pot would normally connect. Jumpers can go like this: InR to OutL and InL to OutR
Old 6th June 2011, 01:53 AM   #2963
pompon is offline pompon  Canada
Here 3 different version of B1 we made ...
The latest version we made ... this proto have near 1500$ just in parts ...
Mundorf Silver&Gold&Oil 1k and 10K
Resistor Vishay the top list
DACT volume control (the top list)
Battery 5000ma 22.2v LiPo
RCA Connector WBT NextGen Gold (I have Silver too but not tried yet)
Batterie connector DIN
Ground wire OCC 7N copper in one big segment
Solder Mundorf
* this is VERY good indeed!
A very very good version here ... A WAY better to the original proto...
Original proto (150$) including the interconnect.
* Not bad but on our system, it's a bit agressive.
Old 6th June 2011, 05:14 AM   #2964
AhFu is offline AhFu  United States
Thanks to the simple circuit design, I was able to build the B1 with most parts from my parts bins, except the FETs. Have been amazed by how natural the B1 sounds so far, to my ears anyway.
Alf
Old 9th June 2011, 02:57 AM   #2965
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
B1 Buffer Preamp
this 'old' LDR/buffer scheme by Nelson Pass use sk170 and sj74
wonder if anyone knows how to convert it to the B1 buffer
Old 9th June 2011, 03:41 PM   #2966
MagnumOpus is offline MagnumOpus  Norway
Nice...the builds on these pages.....you guys are good
Old 9th June 2011, 03:47 PM   #2967
6L6 is offline 6L6  United States
6L6's Avatar
B1 Buffer Preamp
AhFu - nice parts bin you have!!!!!
Beautiful build
Where did you get the R-core?
Old 9th June 2011, 04:39 PM   #2968
flg is offline flg  United States
flg's Avatar
Old?
Peice of cake!
I might even have a dwg by the master himself(at home)? Basically just put the bottom transistor into a current source configuration and change it to the N type device. I guess some of the single endedness of the B1 needs to be addressed as in "symetrical B1 Buffer" thread.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 9th June 2011, 07:04 PM   #2969
Itsmee is offline Itsmee  England
Itsmee's Avatar
If you have already built it, try this
Old 9th June 2011, 11:45 PM   #2970
B1 Buffer Preamp
piece of cake?
would be nice if it were
Itsmee, current source with N device, suggested by flg, is that what you are drawing ?
no, nothing built yet
but I urgently need a preamp
and I have the fets, and matched LDR
well, I also have both "symmetrical B1" boards
but sj74 are rare
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
