B1 Buffer Preamp
B1 Buffer Preamp
Old 27th July 2010, 09:05 PM   #2571
Blues is offline Blues  United States
Blues's Avatar
Yes, this should always be the protocol...no matter how well designed your commercial/diy gear may be.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 27th July 2010, 11:09 PM   #2572
kffern is online now kffern  Australia
B1 Buffer Preamp
Have you sequenced turn on/off? Or tried turning it on w/volume at zero?
Turning it on with volume down makes no difference.
I normally do follow the same sequence but thought wanted to be sure. Don't want to blow my Tannoys. using the wall swith on the SMPS is the best as the power comes on slowly.
Thanks,
Kffern
Old 3rd August 2010, 09:05 PM   #2573
bigaudioscotto is offline bigaudioscotto  United States
Hey Guys
Just thought I would post a couple shots of finished B1.
Old 4th August 2010, 12:19 AM   #2574
Russellc is offline Russellc  United States
B1 Buffer Preamp
Originally Posted by chrismercurio View Post
what I suggested should work to ameliorate this...
And is standard protocol with separates in any event. As has been stated 2 or three times. Why would anyone purposefully turn off or on a pre amp with the power amp already powered up anyway?
Good practice would be not to fool with any thing upstream while the power amp is on. Turning it off first keeps various transients at shut down of upstream components from being amplified and sent to the speakers.
Russellc
Old 4th August 2010, 01:47 PM   #2575
exojam is offline exojam  United States
Here is my progress so far. Just resistors, jfets and some caps. I wanted to wait on getting the enclosure before running any of the wires for everything else. The picture is not the best so I apologize about that.
James
Old 5th August 2010, 02:37 PM   #2576
sandbasser is offline sandbasser  United States
sandbasser's Avatar
Originally Posted by bigaudioscotto View Post
Hey Guys
Nice B1. I'm a little curious about the output wiring...it looks like it is split into 2 sets of connectors but I could be wrong. Would you mind explaining???
Thanks,
- Ray
Old 5th August 2010, 06:18 PM   #2577
I ran 2 more outputs parallel off first set RCA outs.
for Subs, It works great.no drop in volume at all.
Mr Pass told me this would work,and it does perfectly.
Thanks,
Old 5th August 2010, 06:40 PM   #2578
daniloreyes is offline daniloreyes  United States
can you post a picture to see how it is done?
If it sounds good... Listen to it...
Old 5th August 2010, 06:44 PM   #2579
sandbasser's Avatar
Bigaudioscotto's pictures are already posted above in post 2573.
- Ray
Old 5th August 2010, 07:43 PM   #2580
The pic is posted at above 2573.
It is very simple just come off of your existing output RCA
jacks.solder a wire from ground to ground on another RCA.
then simply solder a wire from center pin to center pin .
all you are doing is wiring 2 more RCA parallel off existing Jacks.
just look close at the picture the smallest wire is feeding
the Sub outputs.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
