B1 Buffer Preamp
B1 Buffer Preamp
Old 10th July 2008, 07:54 PM   #221
PSz. is offline PSz.  United States
PSz.'s Avatar
B1 case looks like the ones I use from Context Engineering. Frys electronics carry some of their stuff.
http://www.contextengineering.com/
best regards,
psz.
Old 10th July 2008, 09:00 PM   #222
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
It is not, however. I have my own extrusion die.
Old 10th July 2008, 09:46 PM   #223
PSz.'s Avatar
You have all the cool toys.
best regards,
psz.
Old 10th July 2008, 10:09 PM   #224
Vix is offline Vix  Yugoslavia
Vix's Avatar
Originally posted by Christer
Olive tins sound better.
This can also be the one for B1
http://www.diyaudio.com/forums/showt...17#post1233017
Old 10th July 2008, 10:19 PM   #225
Christer is offline Christer  Sweden
You just reminded me of a similar box I have somewhere. Would be perfect for something small.
Old 11th July 2008, 05:00 PM   #226
fredlock is offline fredlock  United States
http://www.diyenclosures.com/img/pro..._Knobs_Big.jpg
Old 11th July 2008, 05:33 PM   #227
Thanks Andrew.
The enclosure I mentioned above was on sale. Check this ongoing thread, http://www.diyaudio.com/forums/showt...5&pagenumber=6
Old 11th July 2008, 09:13 PM   #228
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
I like re-purposing things for audio projects too.
A couple years ago when my neighbor was moving out, she was going to toss out a wood box for 5 x 8 index cards. Even though it was pretty cheaply made, I hated to see it get tossed into the landfill so I grabbed it figuring I'd do something with it eventually.
The eventually came when a friend of mine wanted me to build him a simple buffer, rather like the B1.
Here it is just after I'd started to line the inside of the lid with 1/8" cork.
Here it is while gluing in some 3/4" maple side panels that will serve as a ledge to mount the top panel inside the box.
The RCAs are mounted to a piece of tempered hardboard taken from an old clipboard. I had it laser cut so the holes for the RCAs would accommodate the "D" flat on them to keep them from turning in the holes. The assembly is then attached to the rear panel of the box with five brass wood screws.
And here it is flipped around to show the business end of the RCAs.
Here's the inside of the top panel.
The transformers are 1:1 bifilar input transformers. The pot's a Penny & Giles RF15.
The buffer's pretty much the same as the B1, except it's using DN2540 depletion mode MOSFETs and using source resistors. It's powered by a split supply and adjustable for offset so there are no coupling caps.
The transformers and perf boards are mounted to 6-32 T-nuts installed on the other side. The top plate is 3/8" Baltic birch.
Here's the top panel set inside the box, which has been trimmed out with the 1/8" cork. The knob is a large (2" at the skirt), art deco-styled bakelite number from the 1940s that I'd found at Leeds Radio.
The counterbores for the T-nuts have since been filled in with drywall compound and sanded flush. The three holes on each side are for the mounting screws that will screw into the maple pieces.
The top will be covered with a nice "cognac" distressed leather and the screws will be brass oval head types with brass cup washers.
Still thinking of a way to dress up all the real estate between the knob and the back of the top plate. Maybe a nice vintage meter or something.
se
Old 11th July 2008, 10:14 PM   #229
Vix's Avatar
Nice
Old 11th July 2008, 10:21 PM   #230
So many transformers Steve. I understand why you need such a large box.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 09:40 AM
