B1 Buffer Preamp
B1 Buffer Preamp
Old 2nd December 2009, 09:10 PM   #2021
Arick is offline Arick  Canada
Arick's Avatar
Originally Posted by udailey View Post
Secret manufacturer?
Yes (just did not want to sound like a sale's rep.)
They are called Brownsburg Electronics and they manufacture all kind of transformers and inductors. All of there products are custom made.
Old 3rd December 2009, 11:51 AM   #2022
Atilla is offline Atilla  Norway
I've a question regarding the possible devices used in this circuit.
What happens if JFETs with lower transconductance are used than the specified ones? Given that we're not having gain in this configuration, does it change anything but the output impedance of the buffer? Which is in the default configuration mostly dominated by the output resistor, if I'm understanding things right.
I've got proper 2sk170s available, fairly well-matched, just waiting for the caps to arrive to build one of those I'm just curious.
Old 4th December 2009, 08:52 AM   #2023
R.I.P.
both the jFETs in the B1 should be sk170. That's a Pass design.
regards Andrew T.
Old 4th December 2009, 09:24 AM   #2024
I've got the signal path wired up with matched 2sk170s.
Oddly enough, this still doesn't answer my question
Old 5th December 2009, 08:46 PM   #2025
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Originally Posted by LucasAdamson View Post
I have the B1 board all populated and soldered. Now I need a power supply.
Many thanks
Lucas
I like batteries as it sounds much better to me, but a wall wart also sounds good and is very convenient. Once I stick it in a final chassis I will most likely use 3x high current 6V SLA batteries for a long lasting supply. A couple of 9V last quite a long time too, at least it is exceedingly cheap to try.
Old 5th December 2009, 08:56 PM   #2026
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
diy is all about cheap, and preferred ideas will you have the batteries in the case or external ?
Old 5th December 2009, 09:31 PM   #2027
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
It will work fine, perhaps not the pinnacle of perfection that
you get with the 2SK170's, but very acceptable, as long as
you can get a few mA of bias.
Old 6th December 2009, 12:13 AM   #2028
Thank you for the answer Mr. Pass.
I'm looking forward to getting my capacitors and finishing the circuit
Old 6th December 2009, 03:41 AM   #2029
most likely external, but the batteries really aren't all that big. I have a lot of Neutrik PowerCon stuff I haven't been able to use yet.
For those of you that haven't tried it, a pair of 9v batteries sounds great.
Old 6th December 2009, 04:13 AM   #2030
CFT is offline CFT  United States
How about using matched pairs of 2sk79 VFETs, anything I should be aware of? Would increasing the supply voltage enhance any performance?
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
