B1 Buffer Preamp
B1 Buffer Preamp
Old 25th October 2009, 02:28 PM   #1971
umut1001 is offline umut1001  Turkey
umut1001's Avatar
oww yes i see now..i forgot the topologies but now i remembered..for single supply ,sinusoidal signal plus dc together goes into the jfet and output cap filters dc..yes i see.thank you
Old 10th November 2009, 06:46 AM   #1972
Nikolas Ojala is offline Nikolas Ojala  Finland
Nikolas Ojala's Avatar
Question B1 in an active filter?
The B1 buffer is essentially a voltage follower.
A voltage follower is also an essential part of a Linkwitz-Riley filter.
See this: Active Filters
Has anyone tried the B1 voltage follower as a component in a Linkwitz-Riley filter?
High-order harmonics are more offensive than low.
Old 10th November 2009, 01:20 PM   #1973
Question B1-converted D/A-converters?
Lampizator is a CD-player or a DAC modification. The idea is to replace the active op-amp filters and buffers after the D/A-converter with a single-ended triode amplifier stage, thus avoiding numerous transistor stages of the op-amps.
I thought that basically the same could be done with a simple Class A JFET amplifier, possibly using a B1 stage. Because B1 is a voltage follower buffer, it could be developed to a Linkwitz-Riley low-pass filter, like I said in my previous post.
Read this too: http://www.diyaudio.com/forums/tubes...yer-sound.html
Old 10th November 2009, 02:24 PM   #1974
DougL is offline DougL  United States
This is a perfect application for a B1 type circuit. For LR4, you probably need 3 B1 circuits, one as input buffer and another for every L2 Butterworth stage.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 10th November 2009, 04:23 PM   #1975
Jacques Merde is offline Jacques Merde  United States
Jacques Merde's Avatar
I agree, it seems like an ideal application for B1. It is on my list of things to do "real soon now".
Old 25th November 2009, 10:24 AM   #1976
derwhalfisch is offline derwhalfisch  New Zealand
I don't really know what i'm doing, but in LTSpice I knocked up a pair of Salas's direct-coupled B1-type buffers in 24dB L/R high-pass, and apart from an enormous insertion loss, it performs as I expected. Oh, and with more than 0.015% THD+N @10kHz but I suspect that's due to the sim looking at everything up to 200kHz. I'd really like to build this to test it, as I'm keen on attempting to bi-amp my system. Should I start a thread on it? I haven't managed to find anything really complete on the 'net so far (so far~) about active crossovers without opamps.
Last edited by derwhalfisch; 25th November 2009 at 10:31 AM. Reason: numbers were wrong
Old 25th November 2009, 11:32 AM   #1977
Floric is offline Floric  Europe
...a pair of Salas's direct-coupled B1-type buffers in 24dB L/R high-pass, and apart from an enormous insertion loss, it performs as I expected...
I don't see any reason for this insertion loss. And as far as I remember, there was none in my simulations. I think you did something wrong.
You should not trust the THD+N simulations of spice too much. Just regard it as a tendency.
regards
Flo
Old 25th November 2009, 11:40 AM   #1978
@Floric:
I'm sure I did something wrong ;P
Old 25th November 2009, 01:31 PM   #1979
AndrewT is online now AndrewT  Scotland
in the passband of each part of the crossover there should be near zero insertion loss.
You either (virtually) wired it up wrong or you asked the simulator the wrong question.
regards Andrew T.
Old 25th November 2009, 01:44 PM   #1980
Figured it out, crossover resistor values were too low compared to the input 'stopper'... less than 1dB loss now.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
Copyright ©1999-2017 diyAudio
