B1 Buffer Preamp
B1 Buffer Preamp
Old 6th July 2008, 04:29 PM   #171
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
B1 Buffer Preamp
Default Re: Input Impedence
Originally posted by Diomedian
The effects I'd notice if input impedance went too low would be just more noise, is that right?
It's in fact the opposite. Assuming you are talking of source impedance in parallel with attenuator.
Old 6th July 2008, 05:17 PM   #172
Diomedian is offline Diomedian  Canada
Default Re: Re: Input Impedence
Alrighty - either I'm asking the wrong questions, or the questions don't make any sense, or my assumptions are wrong, or... some combination. :-) Please treat me like I don't know anything, because this is a reasonable approximation of actual knowledge.
1) It is desirable for the buffer to have high input impedance? This makes it easier for the source to drive - yes?
2) The input impedance of the B1 is determined solely by the pot? This is because the source sees only a 25K resistor (the whole length of the pot)?
3) On the B1 side of the pot, it sees a 1K in series with a variable resistance (some part of the pot), and a variable resistance to ground (the rest of the pot) paralleled with output impedance of the source?
4) If I replace the pot with a 2K resistor, (that is to say the circuit now looks like input -> 1K -> 1uF -> 2sk170, and input -> 2K -> ground), the input impedance of the B1 is now 2K, is that correct?
5) Doing as in question 4) - this is the equivalent of a shunt-type attenutator set to min volume (assuming 2K is the smallest value used by the attenuator)? Er... or is that max volume?
6) Would a ladder-type attenuator be a better idea for this circuit since the shunt-type gives such a low input impedance?
7) Finally, is there a reason a linear taper pot was used, and not a log scale? Was it simply cheaper, or does this circuit for some reason require a linear pot?
Or... should I just stop asking all these silly (and possibly terribly insignficant) questions and just go test it for myself? hehe
Thanks in advance, and sorry for all the noise on this thread...
-d
Old 6th July 2008, 06:30 PM   #173
analog_sa's Avatar
B1 Buffer Preamp
1. Yes.
2. 25k in parallel with 1M. Still 25k.
3. Yes.
3. Yes
4. No. There is also a resistor in series with the input which generally determines the worst case scenario as seen from the source
5. As in 4. Max volume is determined by series resitor and max value of shunt; if shunt is open circuit there is no attenuation. If shunt is a pot attenuation is set between pot value and series resistor. Min volume is set at min value of shunt (0 ohm)
6. ???
7. Log pot would work just as well
Your questions are not silly. If you want to see silly i can point you to a few threads to compare
Do you intend using a rotary switch or a pot for the shunt? If using a pot you are likely to lose some voltage gain at max setting across the shunt. You can calculate this depending upon the resitor values and see if it's acceptable. Most people use shunt controls as a good compromise between quality and cost - a really nice series resistor and a cheap pot sounds significantly better than a cheap pot on its own.
Old 6th July 2008, 07:17 PM   #174
khundude is offline khundude  Canada
I think the "ladder" and "log" are the same, no? This is were a series of relays is used so that they are not in the chain.
Old 6th July 2008, 08:13 PM   #175
juma is offline juma  Germany
juma's Avatar
No, it's not the same, it's not even something you can directly compare.
"Ladder type attenuator" refers to topology, to way how the attenuator is built, ladder-like.
"Log" refers to attenuation characteristic, it represents mathematical function of change of resistance from potentiometer's/attenuator's wiper to ground and number of degrees when you turn the knob.
Example:
a) We have 10k log. potentiometer/attenuator . We turn the knob to 12 o'clock position. Resistance from wiper to ground is 500 Ohms.
b) We have 10k linear potentiometer/attenuator . We turn the knob to 12 o'clock position. Resistance from wiper to ground is 5k.
Oh boy, I wish I could put it clearly in less words
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 6th July 2008, 08:44 PM   #176
6. ???
Thanks for all the replies analog_sa!
To rephrase #6, I was thinking that since using a shunt-type attenuator causes input impedance of the buffer to vary with the volume setting, would it be better to use a ladder-type attenuator (not in shunt mode) that doesn't cause the input impedance to vary?
If I use a shunt at all, it would be with an attenutator.
thanks again,
-d
Old 6th July 2008, 09:01 PM   #177
supernet is offline supernet  Europe
supernet's Avatar
Should I expect higher noise and THD figures, if I use LM 317 regulator with CRC filter for PSU instead of discrete one?
Old 6th July 2008, 09:13 PM   #178
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
use stacked 317s , with both heavy bleed and mucho uFs on output
( in that case with all necessary diodes for chip protection)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th July 2008, 09:32 PM   #179
supernet's Avatar
OK.
I will use two separate regulators for each channel. I was thinking to use 2X4700 uF 35 V before LM 317 and 100 uF at the outout. For the buffer, I will probably use two 4700 uF caps / mono channel instead od 15000 uF.
Should this be OK?
Old 6th July 2008, 10:27 PM   #180
Zen Mod's Avatar
B1 Buffer Preamp
OK.
Should this be OK?
when I wrote stacked , I meant as in attached schm . - cascaded 317 , with ref leg of input one connected to output , not to ground ;
that way input one is prereg for second 317.
heavy bleed - I meant - put resistor load on output of reg
in fact - you can pretty easily use exact schmtc
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
