B1 Buffer Preamp
B1 Buffer Preamp
Old 26th May 2009, 09:58 PM   #1701
timothyshields is offline timothyshields  United States
Default Re: Re: Status of first build
Originally posted by Nelson Pass
Those are perfectly fine.
I was all set to order new posts, but single pots are unavailable at this time (backorder). An alternative plan is to use a dual pot and rotary switch instead of DPTP switch and single pots. Considering one of the two dual pots below, and the switch. I do not listen to system at high volume, so I want some useable range from pots at lower volumes. I am begrudgingly living with reverse log taper at the moment and find it not suited to my preferences, yielding too much increase in volume at the lower end of the throw. Any opinions or affirmations will again be most appreciated.
Linear taper dual pot (concerned with 10K OHM rating)
http://search.digikey.com/scripts/Dk...=KKU1031S28-ND
Log taper dual pot
http://search.digikey.com/scripts/Dk...=KKA5031S28-ND
Rotary Switch (very much conjecturing what will work here)
http://search.digikey.com/scripts/Dk...name=GH7102-ND
Old 26th May 2009, 10:37 PM   #1702
Lee35210 is offline Lee35210  United States
Default reverse taper
a quick fix is to revers the outer 2 wires on each pot and use them in reverse ie CW is lower volume, CCW increases volume. Works as long as you remember!
Been there, Heard that, Forgot what I was listening to!
Old 27th May 2009, 02:44 AM   #1703
Default Re: reverse taper
Did that, by accident, but only for one channel. So quickly turned volumes clockwise in reaction, elongating the hair-raising experience. Given my preteens often use the system, I'll invest in the correct taper. It was hard enough to teach them to wait for the tube amp before setting the volume.
Old 27th May 2009, 02:53 AM   #1704
Default Re rewire
Understand completely. was just a quick and dirty fix until can procure correct pots
Old 28th May 2009, 02:56 AM   #1705
budwiser is offline budwiser  United States
So much information. So am I missing anything if I just build the B1 as designed.
Old 28th May 2009, 10:24 PM   #1706
VT67 is offline VT67  Belgium
VT67's Avatar
Maybe off-topic or silly, but would this B1 Buffer Preamp together with a Zv9 make a good integrated amp?
Old 28th May 2009, 10:59 PM   #1707
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
No, I don't think so . . .
Old 29th May 2009, 01:00 AM   #1708
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
B1 Buffer Preamp
The total gain might be an issue, as the ZV9 has about 13 dB or so.
I tend to use efficient drivers with that amp, so it has not been a
problem for me.
Old 29th May 2009, 02:23 AM   #1709
Keith Lockwood is offline Keith Lockwood  United States
I have already purchased two of the Pass DIY B1 boards with the matched JFET's.
I bought two because I wasn't sure if one of them would comfortably drive my 100K input impedance amp as well as a typical subwoofer plate amp which are quite often 10 to 20K as far as their input Z. My original idea was to set one up with fixed resistors in the stead of a volume pot for the low impedance load and one with the volume control.
Is this wacky thinking? Is one plenty and not to worry about the 5 to 10 times difference in impedance? If this were in fact a good idea what would be the best way to implement it, i.e. wire this mess together. Perhaps wire the fixed unit for the plate amp from a second output or in parallel from the unit with the volume control?
My second question is about the use of stepped attenuators. I have always hated dual volume controls. I also have no need for a balance control in my room, just lucky that way I guess. Part of my plan in the future may be to use a motorized remote control from Bent Audio on a 20K DACT or 20K or 25K Goldpoint.
I am a bit confused about the whole issue of taper and if the stepped units are suitable. I have some experience with comparing a 100 DACT with a 100k "blue velvet" Alps and there was no comparison in my mind as to which sounded cleaner , clearer or more realistic. It was the DACT all the way. I hope not to offend anyone but It made the Alps sound like a toy.
I am not new to audio just new to DIY and have a lot to learn.
Old 29th May 2009, 05:21 AM   #1710
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
That depends on what you want. If you want to go capless then the standard design will not fit the bill.
It's only audio. Member of the non modular PCB design committee
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
