#1601 | |
diyAudio Chief Moderator
#1602 | |
so it would be better to put that R1 on the volume switch or at PCB of B1 ? sorry for my stupid question Salas. i'm newbie about electonics. Thank's La Ode |
#1603 |
Better near the JFET on pcb.
*There exist no stupid questions. Only silly problems if simple questions haven't been asked. |
#1604 | |
![]() now i'm ready to design the PCB layout. i will use LM317/337 too for voltage regulator (like in your schematic) BUT can i stick with (1ohm, and 15000uF) after the reg ? like in original B-1. {see attachment} picture Thank's La Ode |
#1605 |
It can work, but it would work better if the big capacitors are before the regulators and the 1000uF ones after.
#1606 |
diyAudio Moderator Emeritus
15.000 uF will be a little overkill but I could be wrong in the eyes of many. Better use two 2200 or 4700 uF caps with a resistor or coil in between. Everything before the regs of course. After the regs 100 uF and a 0,1 uF MKT/MKP. Some regs do oscillate with 1000 uF at the output.
I would advise to use separate supplies for the 2 channels. It could be wise to provide pads for shorting the input and output caps. Just in case the source has a DC component you can remove the jumper and you will have a coupling cap. Just an idea that adds functionality that could be useful. Maybe I am old fashioned but if you provide board space for a RK27 potentiometer you could add an input RC filter before the potentiometer to avoid RF straying in. A -3db point of 40 to 50 kHz would be enough. You never know with all the RF garbage in the air. The B1 has a bandwidth of 10 MHz if I am not mistaking. The icing on the cake would be 4 or 5 relay switched inputs. That would be a PCB for "B1 Deluxe" everyone will want ![]() me too...
It's only audio |
#1607 | ||
Thank's for advice Salas and Jean-Paul. ![]() now, the layout about 60% to finished and maybe on saturday i can bought my layout to the PCB maker and take 4-5 days to finished. I can not wait any longer to build this one too. La Ode |
#1608 |
How critical is the 1uf. cap tolerance for C2, C100 and C200?
Thank you all for this wonderful tread. Jacq. |
#1609 |
I am nearly done building my B1 preamp, thanks to Colin at DIY Pass and those who kindly responded. That said, I'm not quite sure where I choose to use the preamp. In one set up I can utilize the unbalanced RCA outputs, but in another the amplifier requires balanced XLR inputs.
I have seen some discussion of this topic before, albeit I am unsure on how to proceed. Any suggestions would be much appreciated. Timothy |
#1610 | |
-j |
| buffer/preamp? | TheDriver41 | Chip Amps | 2 | 3rd October 2004 08:40 AM |
