B1 Buffer Preamp
B1 Buffer Preamp
Old 29th March 2009, 12:06 AM   #1541
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
Originally posted by maxlorenz
Hi Salas,
Avoiding crossover distortion and "coloring" the sound at our liking?
I've been told that some Tube amps do have capacitors on the signal path...
Anyway, I'll soon make that capacitor-less buffer for my TVC
I hope it is not too neutral...
M
this gadget is SE , so there is no any xover dist ;
even in case of (almost any) other buffer I know - there is no any xover dist , because they're all A class
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 29th March 2009, 12:17 AM   #1542
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
Without being sure, maybe Max refers to alleged capacitor distortions described as ''crossover'' too, maybe you remember the battery bias on caps stuff by JBL etc. In the end, the electrostatically microphonic nature of cap foil following rather high signal voltage as in speakers, seems to stay put by some DC voltage bias IMHO.
JBL paper
Old 29th March 2009, 12:22 AM   #1543
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Without being sure, maybe Max refers...
No. My bad...I wrongly though that dual supplies would make this (even if class A).
Thank you, gentlemen.
Old 29th March 2009, 12:23 AM   #1544
Salas's Avatar
B1 Buffer Preamp
Page 10 and page 12 for those interested on the whole reference.
Old 29th March 2009, 12:31 AM   #1545
Zen Mod's Avatar
B1 Buffer Preamp
Default not off topic if put in B1 shebang ;)
that issue mentioned several times over at Audiokarma ,especially in Econowaveguide thread ...
interesting , indeed ...... another toy for grown man (called DiyA)
Old 29th March 2009, 12:34 AM   #1546
Salas's Avatar
B1 Buffer Preamp
I have done that in speakers, it helps cheaper caps to focus sonically. But you will not find zero crossing distortion. People tried to measure such, could not find. Its the electrostatic thing IMHO. In tight caps it does not much difference in my experience.
Old 29th March 2009, 04:47 AM   #1547
Kinnja is offline Kinnja  United States
Default capacitorless B1
Revised schematic.
http://www.diyaudio.com/forums/showt...10#post1591410
A reminder of Salas version since its been mentioned.
Is this still the most recent version?
Would any jfet suitable for the Pass B1 also work here?
I was considering building this before but couldn't figure out what I needed to look for in a relay. Does the 12V refer to Coil Voltage? What does the 700R refer to? I didn't see any similar spec to select for at the suppliers I usually buy from.
Is the npn pair literally *any* npn pair? Or any npn pair that makes sense, at least to someone who understands what they're looking at? And it is a Darlington pair right?
Any comments on parts for this circuit would be appreciated. And thank you Salas of for sharing.
Old 29th March 2009, 07:21 AM   #1548
dejanm is offline dejanm  Austria
This design made by Salas looks really good. I would say it is an improvement to the "original" Pass B1 design for obvious reasons. I wonder only whether for this design a shunt reg after LM317 would bring some further improvements, especially if you omit large input elco, used for filtering ?
For those of you interested in further improving of this simple B1 design, this is a recommended reading:
http://www.borbelyaudio.com/adobe/ae699bor.pdf
Old 29th March 2009, 10:45 AM   #1549
Salas's Avatar
B1 Buffer Preamp
I use this for secondary duty, so I did not change it. Of course symmetric shunt regs instead of 317 will bring benefits. But I don't know if it will seem worthy to all people given their dedication and individual system resolution. Its much more costly for time and space or dissipation.
*12V 700R refer to the particular relay coil characteristics (typical to find).
** Any NPN pair means just a couple of NPN transistors. One used as a diode, the other under the relay to pull its coil.
*** 1k and 330R can be lower, say 220R each if no oscillation is manifesting given the particular input and output cabling. That, makes it more dynamic subjectively.
**** I haven't used other than 2SK170BL
Old 29th March 2009, 11:20 PM   #1550
Default Re: capacitorless B1
Originally posted by Kinnja
....And it is a Darlington pair right?....
How did I miss that? Definitely not a darlington.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
