B1 Buffer Preamp
B1 Buffer Preamp
Old 25th March 2009, 11:54 PM   #1531
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
B1 Buffer Preamp
Default balanced setup.
Didn't someone earlier do a post about using the traditional B1 schematic in balanced operation by using the out's on these tied to a 1 and 2 of XLR? I can't seem to find such a post. Was I dreaming it?
Old 26th March 2009, 01:06 AM   #1532
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
B1 Buffer Preamp
Default Re: balanced setup.
dunno .....
maybe I did ...... maybe not ;
use one stereo B1 per channel ....... one channel of B1 for pos. leg , other channel of B1 for neg. leg
look in PSM LS thread to see how 4 separated buffers are used for balanced operation .
peace of cake .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th March 2009, 06:08 AM   #1533
dejanm is offline dejanm  Austria
Some first reflections on B1 ... Remark: I am talking here about "original" Pass B1 design.
I had some thoughts on power supply. The question was how much to invest in it: whether to go with good shunt reg or to use something simpler or even to go with something very simple - that was the first question ..
So together with a friend of mine I put simple power supply of 18 V DC: transformer -> elco -> standard LM317 Reg -> B1. On the input of B1 I have Nichicon Elco of 15 mF, 25V. On the other side I put together simple battery supply made of lot of AA Alcaline 1,5V batteries. The voltage was the same: 18V DC. I installed a switch so that I can easily switch from one supply to another. And I couldn't really hear any difference in sound reproduction.
Then I increased the battery voltage to 23V. And again I couldn't really hear any difference. I know that THD is lower when the voltage is higher but in real life I cannot make difference ... at least not on the system where I was testing (solid middle of the class HiFi system).
These are some experiences that might help somebody. My personal conclusion is that B1 is made as a simple buffer and that it should be kept simple. Maybe some experiments with input and output caps would be interesting (for example with Auricaps) but power supply should be done correctly but there is no real need for some extravaganza ...
http://i277.photobucket.com/albums/k...604/PassB1.jpg
Old 28th March 2009, 01:04 PM   #1534
rob lenk is offline rob lenk  United States
Default b1-redux
nice comparison-interesting conclusion
thank-you
my thoughts when looking at your pics -are now upgrade the vol pots with the same battery vs simple regulation power supply and see if you can hear a difference.
thanks for your shared experience
rob
Old 28th March 2009, 01:13 PM   #1535
Face is offline Face  United States
Face's Avatar
I've tried Jantzen, Dayton, Sonic Caps, and Claritycaps in my B1, IMO the type of capacitor used can make an substantial difference.
Old 28th March 2009, 01:20 PM   #1536
Diomedian is offline Diomedian  Canada
Default Re: b1-redux
I don't see a pot at all in that pic - is one being used?
-j
Old 28th March 2009, 02:00 PM   #1537
Tea-Bag's Avatar
B1 Buffer Preamp
Sure, what's your ranking?
Old 28th March 2009, 02:14 PM   #1538
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
B1 Buffer Preamp
I am still wondering why paying for quality capacitors when B1 can safely be made without input and output coupling if using symmetric (+/-) supplies. I still use it like that for months now, and the offset is practically null. And no cap always sounds better than any cap.
If I was using B1 for main system, I would use +/- 10V Mosfet shunts, and minimal applicable Shinkoh input and output series resistors (after test in given system for square waves). That is how making it for top performance.
Old 28th March 2009, 11:51 PM   #1539
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Hi Salas,
Avoiding crossover distortion and "coloring" the sound at our liking?
I've been told that some Tube amps do have capacitors on the signal path...
Anyway, I'll soon make that capacitor-less buffer for my TVC
I hope it is not too neutral...
M
Old 29th March 2009, 12:04 AM   #1540
Salas's Avatar
B1 Buffer Preamp
Its not cold when capacitor-less, it sounds neutral but soft. Maybe a bit ''gray''. The input and output resistors values and quality as well as the pot seal the tone. +/- 10V is the sweet spot I found for most relaxed sonics.
In tubes the capacitors are more to see because of the vacuum device one way nature, economic and bulk cost of extra PSUs etc. Every time we use better capacitors, they show there too. So it would be better if they weren't needed.
B1 Buffer PreampHide this!Advertise here!
buffer/preamp? TheDriver41 Chip Amps 2 3rd October 2004 08:40 AM
